Adequate operating water temp
Old Feb 14, 2012 | 07:54 PM
Nategreat923's Avatar
Default Adequate operating water temp
So I have a bone stock D15 and lately I've been reaching 91 degrees celcius. Usually it stays around 89. Is this still an exceptable temp to reach? Or should I start to worry?
Old Feb 14, 2012 | 08:24 PM
Cjlarson14's Avatar
Default Re: Adequate operating water temp
What degree thermostat do you have on the car?
Old Feb 14, 2012 | 08:27 PM
I want to say 89, but I honestly do not remember. Whatever autozone gives out.
Old Feb 14, 2012 | 08:29 PM
Cjlarson14's Avatar
I had a d15 as well and stock thermo was a 180 degree. Your talking celsius so stock should be 82/83. 89/91 sounds a bit high for the car. Bad thermo/wrong thermo maybe?
Old Feb 14, 2012 | 08:39 PM
See, if I floor it and hit ~7000 RPMs it drops to 79 degrees.
Old Feb 14, 2012 | 08:44 PM
Cjlarson14's Avatar
I'd say replace the thermo if its a big issue to you. $15-20 and an easy fix if you know what your doing.
Old Feb 14, 2012 | 08:53 PM
Yeah, I guess ill try a new one. But I just put this one in ~5 months ago.
Old Feb 14, 2012 | 08:55 PM
Cjlarson14's Avatar
Well in that case, do you have enough coolant in your radiator and resevoir tank?
Old Feb 14, 2012 | 09:10 PM
Yes, and there are no air bubbles. Also has a newer HG, radiator, rad cap and hoses.
Old Feb 14, 2012 | 09:16 PM
Cjlarson14's Avatar
Sounds good to me then. Is the timing on the car correct? If so then this brings me back to the thermostat. Try a 180 degree thermostat.
hardrock2401
Aug 31, 2014 08:24 AM
4doorpowa
Jan 24, 2011 12:50 PM
chafetzk
Dec 8, 2010 04:57 PM
tianporn
15
May 21, 2005 09:16 AM
Jmunk
Oct 19, 2004 02:51 PM
