90 CRX Si Lighting issues. ICU?
Old Feb 14, 2012 | 05:58 PM
RanCRX's Avatar
Icon3 90 CRX Si Lighting issues. ICU?
Just recently, like three days ago. I started to have problems with my corner lights (amber side). The stay on light part of the corner lights started flickering. Then when I use the left turn signal, the right turn signal comes on too. Now the corner light stay on lights don't come on at all.
I tested the hazard switch, all was fine, but leaving it on for 30 seconds, it also died. Although while it was working the turn signals part of the corner lights work (clear side), but the stay on lights (amber side) which are also turn signal lights don't come on.
I can still use the turn signals, the green arrows comes on the instrument panel, you hear the ticking.
The bumper lights now don't come on. Also, the instrument panel light does not come on, nor the stay on lights of the back tail lights come on either.
Headlights work, brake lights work, reverse lights work.
Everything else works good. Radio, etc.
I took out the ICU after hearing other issues from all sorts of forums and took a picture of it. It's burnt up a bit.
I'm wondering if I can still clean it with q-tips and alcohol, and most likely if not, should I buy a new ICU or a used one? Where am I able to get a new ICU if I were to buy one? I will try the Honda dealer tomorrow.
Any help gladly appreciated
Old Feb 15, 2012 | 06:32 PM
fcm's Avatar
fcm
Old Fart
Default Re: 90 CRX Si Lighting issues. ICU?
Thar ICU is toast, replace it, that should solve the sidemarker issues.
It is burnt pretty bad, do you have anything wired to the front side markers, euro side markers maybe, changed the wattage of the side marker bulbs? 94
rdemel
Honda Civic (2001 - 2005)
May 15, 2017 05:26 AM
RanCRX
Feb 16, 2012 10:53 AM
o0oz
Jan 3, 2007 08:22 AM
CRXObsession
Sep 25, 2005 07:22 PM
Pandahatch
11
Dec 8, 2004 01:49 PM
