ECU FUSE BLOWS AND BURNED ECU
Old Feb 14, 2012 | 10:47 AM
BOOSTEDCRX68's Avatar
Icon7 ECU FUSE BLOWS AND BURNED ECU
I SWAPPED OUT MY ACCORDS ENGINE WITH THE SAME YEAR VEHICLE ENGINE BUT THE NEW ENGINE IS A VTEC AND NOW I HAVE A PROBLEM WHERE MY ECU FUSE KEEPS BLOWING OUT AND I BURNED THE ECU CAN ANYBODY TELL ME WHAT TO LOOK FOR
Old Feb 15, 2012 | 03:30 PM
phootbag's Avatar
Default Re: ECU FUSE BLOWS AND BURNED ECU
Sounds like a short circuit. Look for a short circuit. Could be a pinched wire or simply a connector hooked up to the wrong load causing a low resistence fault, blowing a fuse and ruining the ECM.
I've seen a similar thing on a customers car where one of our techs installed an engine from a prior year into a CRV. The connectors all went into place but some of the loads in the transmission wiring were different. Smoked the ECM.
Old Feb 15, 2012 | 10:23 PM
kageshin's Avatar
well, since you replaced the non-vtec engine with a vtec version (assuming it's same type of tranny) then simply go down to your local scrap yard and get a ECU that's for the engine you replaced.
PS: don't forget to get key programmed if it's equipped with IMMO
hoursinexile
Nov 17, 2009 10:14 AM
LOMPSEG
Engine Management and Tuning
Apr 2, 2009 08:52 PM
94SuperLudeSI
Apr 20, 2008 06:10 AM
WheAs MaI MojO
Jan 30, 2003 07:49 PM
talonfred
Jan 3, 2003 10:16 PM
