98 civic fuel pump toggle
Old Feb 13, 2012 | 02:52 PM
98EJ7Y8's Avatar
Default 98 civic fuel pump toggle
what do you guys think about putting a toggle switch on the fuel pump .. cant seem to get power to the pump
Old Feb 13, 2012 | 03:32 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: 98 civic fuel pump toggle
have a look at your fuses
try to get a multy meter at the pump see if you have 12v
Old Feb 13, 2012 | 03:39 PM
98EJ7Y8's Avatar
i checked the relay and its good .. jumped the pump and car started right up .. but when i use the key to try the pump its a no go .. could it be i need the obd2 to obd1 jumper harness ?? or something else
Old Feb 13, 2012 | 03:43 PM
Former User's Avatar
The main relay is a safety device. Don't bypass the relay. Fix the problem.
Old Feb 13, 2012 | 03:45 PM
sc440's Avatar
What motor what ecu? Have you checked cel's,if you have a solid cel could be ecu.
Old Feb 13, 2012 | 03:51 PM
98EJ7Y8's Avatar
i dont plan on bypassing .. never thought of it once... and i have a mini-me d16y7 with a d16y8 head, harness and all y8 sensors .. i am running a p2p ecu .. currently waiting on a obd1 chipped ecu .. the relay is good the pump is good .. just cant seem to get power to the pump .. i checked the fuse in the box next to the pedals but everything seems to be good .. i thought it was the ecu at first but was told from many of different people that it wouldnt be the ecu no matter what .. but the ecu is where im at now
Old Feb 13, 2012 | 04:13 PM
sc440's Avatar
Check power at map sensor with key on run,should be 5 volts,if its less or none its ecu.
The ECU controls when the fuel pump primes by providing ground to the main relay. Check whether this ground wire is good.
Old Feb 13, 2012 | 04:19 PM
sc440's Avatar
Ground at thermostat
Old Feb 13, 2012 | 04:26 PM
Ultimately yes, but if the thermostat ground were bad, the engine would lack both spark and fuel. The OP needs to check the fuel control wire running between the main relay and ECU.
Old Feb 13, 2012 | 04:27 PM
98EJ7Y8's Avatar
thanks ronj@ht .. and on the other hand .. how hard would it be to put a toggle switch with a fuse in the correct way ?? really dont plan on doing this but just wondering if its a possibility if this is the way i have to go
Old Feb 13, 2012 | 04:29 PM
98EJ7Y8's Avatar
thanks again ronj@ht
so far youve provided me with the best answers and they are understandable also
Old Feb 13, 2012 | 04:30 PM
98EJ7Y8's Avatar
and thats not the case at all cause i got spark just cant get the pump to power with the key .. when the pump is jumped with a 12v power source .. the car runs
Old Feb 13, 2012 | 05:12 PM
sc440's Avatar
I had same issue. Have you checked the check engine light codes? Is the cel solid or does it blink a solid cel indactes bad ecu,also checking for proper voltage at map when key is on run postion is a easy way to check if ecu is good should be 5 volts if there is not yor ecu is bad. Mine had 2.4 volts
Old Feb 13, 2012 | 05:27 PM
98EJ7Y8's Avatar
how did u end up fixing the problem??? .. and im waiting on a new ecu (chipped p28 ecu with deleted o2 sensors ) dont know what else to do .. everything is good ( basically brand new )
Old Feb 13, 2012 | 05:37 PM
sc440's Avatar
Ecu was bad,i had another chipped ecu it fixed the problem search on here i think ALLMOTOR had a similar issue with his.
Old Feb 13, 2012 | 06:02 PM
98EJ7Y8's Avatar
thanks hopefully i get this ecu and it fixes everything
Old Mar 30, 2012 | 07:58 PM
delsol1225's Avatar
did you fix the problem?
i have the same problem on my car.
Zack1
Feb 22, 2017 08:32 AM
mighty_sol
Jan 27, 2014 11:33 PM
blackeg
Mar 15, 2007 11:46 AM
bc matt
Apr 2, 2005 01:17 PM
partyguy1516
Dec 28, 2003 05:14 PM
