99 civic coupe won't run after engine install
Old Feb 13, 2012 | 10:22 AM
jdavis290's Avatar
Icon2 99 civic coupe won't run after engine install
Recently purchased a 1999 civic coupe and an ls v-tech motor. Got the motor installed but now it wont run. It turns over, but I am not getting any spark and my fuel pump is not kicking on. I have an obd2b distributor with an obd1 ecu and an obd2b to obd1 jumper harness. I have tried switching out dizzy's, the edu, and the main relay and still have the same results. I was told it could be the aftermarket alarm system that was installed into the car before I purchased it. I don't know what the problem could be. Anyone have any idea's?
Old Feb 13, 2012 | 10:25 AM
thenext's Avatar
20% cooler
Default Re: Can't figure it out!
Have you checked all of your grounds?
Old Feb 13, 2012 | 10:27 AM
sfar785's Avatar
sounds to me like you got a bad ground somewhere. Try the ground that's attached to your thermostat.
Old Feb 13, 2012 | 10:34 AM
jdavis290's Avatar
All the grounds have been checked and re-checked. It's the first thing I thought of. Any other ideas?
thenext's Avatar
20% cooler
Have you been through all the fuses and relays?
Old Feb 13, 2012 | 10:37 AM
jdavis290's Avatar
All the major parts work fine in another EK. Could the aftermarket alarm system be shutting down the distributor and fuel pump? The alarm appears to be coming from 6 or 7 leads from the steering column, can I just pull it out?
jdavis290's Avatar
Yes, all the relays and fuses are good
Old Feb 13, 2012 | 10:41 AM
thenext's Avatar
20% cooler
If you think it might be the alarm, disconnect it from the vehicle and see if it starts up.
Old Feb 13, 2012 | 10:53 AM
sfar785's Avatar
some alarms will kill everything when disconnected. But if you checked grounds/fuses/relays then it probably is the alarm.
Old Feb 13, 2012 | 10:58 AM
jdavis290's Avatar
Thanks ya'll. Will try to completely remove the alarm system and see if that fixes the problem
Old Feb 13, 2012 | 11:02 AM
Former User's Avatar
Default Re: 99 civic coupe won't run after engine install
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old Feb 13, 2012 | 12:52 PM
jdavis290's Avatar
So apparently we have the wrong wiring harness in the car as well. Turns out it was NOT an obd2b so now I have to try and find the right wiring harness as well as figure out this alarm thing
Old Feb 13, 2012 | 01:10 PM
sfar785's Avatar
if you get the correct harness you should be able to keep that alarm
Zach18
Honda Civic (2001 - 2005)
Oct 23, 2016 08:30 PM
viciousef9
Audio / Security / Video
May 12, 2009 10:52 AM
letholone
10
May 7, 2009 05:39 PM
hirevmaniac
Dec 18, 2005 06:18 PM
