93 civic swap..maybe?
Old Feb 12, 2012 | 12:46 PM
richard78's Avatar
Default 93 civic swap..maybe?
my girlfriend wrecked her 97 civic ex(4door auto). the body is a loss, but eng/trans still good. i have a 93 lx body i bought a while back and was wanting to install the y8 into this 93'. is this possible or is it just to much of a pain to fool with since the y8 is obd2 and the 93 is obd1?
Old Feb 12, 2012 | 01:18 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: 93 civic swap..maybe?
Very easy swap!!!
Old Feb 12, 2012 | 04:24 PM
94EG8's Avatar
Seagull Management
You can't use the Y8 transmission or the ECU, you can use the engine, but you'll need to swap the intake manifold and throttlebody and you'll need to run a chipped and tuned OBD1 ECU. You'd also want to reuse your distributor, alternator and injectors. A better idea would probably be to sell the swap (you may have a really hard time selling the auto tranny and ECU) and use that money to buy a D16Z6 and ECU.
Old Feb 12, 2012 | 06:13 PM
mf10_eg88's Avatar
^ x2
Old Feb 19, 2012 | 01:46 PM
richard78's Avatar
thanks guys, that helped alot.. ditched the y8 swap all together and found a the stock setup pretty cheap. now i just have sell the y8 setup.
Old Feb 19, 2012 | 06:19 PM
hondasdohc's Avatar
You can put it in a 93 even though it's obd2 but you need to get a p06 and injectors for the p06 and a tranny assuming you have a 5 speed trans on the 93. That's all you need to do and get a d series distriutor for obd1 and there the y8 is converted obd1 using the 93 wiring harness.
HoodbillyLG
May 24, 2017 06:31 PM
98integralsB18
Apr 16, 2011 10:07 PM
LuckyXIII
Oct 24, 2008 09:16 PM
97gSrkId88
Jun 7, 2006 08:03 PM
jinteg730
Dec 8, 2004 06:08 PM
