Help, Removing valve seals
Old Feb 12, 2012 | 12:07 PM
Jerry Michaels's Avatar
Default Help, Removing valve seals
Any got any tricks and or tips to get this SOB'S! out? or just break down and have it taken to a machine shop?
Old Feb 12, 2012 | 04:38 PM
IN VTEC's Avatar
Default Re: Help, Removing valve seals
I use a slide hammer tool that I bought from Goodson. Worst-case if I can't get the jaws under the seal, then I wiggle it up a little with a pair of pliers.
I've never done it before but I suppose you could heat up the rubber enough to soften it and then wiggle them off with pliers or the slide hammer. I would apply heat slowly and probably only want to use a propane torch... no MAP or Oxy-A.
Old Feb 13, 2012 | 06:10 AM
kp's Avatar
kp
Patience and pliers.
Old Feb 13, 2012 | 06:12 AM
tron_'s Avatar
10 Year Member
channel locks and grunting did it for me
Old Feb 13, 2012 | 12:06 PM
Muckman's Avatar
Moderator in Chief
I use this KENT MOORE EN-46116 VALVE STEM SEAL REMOVER INSTALLER
Kr4nG
Nov 2, 2009 01:53 PM
turbotime
Nov 12, 2006 04:34 PM
hu
Mar 29, 2006 10:17 AM
RACEPAK
11
Dec 11, 2005 03:03 PM
Civicr2gs5
May 5, 2004 03:18 PM
