need help (em1) D16y7 to D16y5
Old Feb 12, 2012 | 11:57 AM
ENvUS EM1's Avatar
Default need help (em1) D16y7 to D16y5
whats up h-t
alright so im getting tired of my y7 and im getting a cheap deal on a y5. the motor missing intake mani and wire harness. i wanted to know what whould work with this swap if i cant find any hx wiring harness....
could i use the y7 harness and y7 o2 sensor?
if so do i can i run the p2n or do i run the p2e ecu with a vcon?
thanks for your help
btw this is my first post on here
Old Feb 12, 2012 | 03:53 PM
usdm-honda-r18's Avatar
Default Re: need help (em1) D16y7 to D16y5
Why do u have (em1) in your question? If its an em1 you should have a b16 unless it was swapped out...
Old Feb 12, 2012 | 04:03 PM
canadaek's Avatar
um why do you have a y7 in a em1 (99-00 civic si) and a y5 is not an upgraded it's for fuel economy also the y5 used an egr valve and a 5 wire o2 sensor so you would need that manifold . if it is really an em1 stick a b series vtec motor back in it
Old Feb 12, 2012 | 07:32 PM
Townson's Avatar
lol whatttttt? im sorry but the y5 is the retard of the honda motor family. and if its an em1 then it should have a b16 not a y7.
Old Feb 12, 2012 | 08:29 PM
jbpnoman's Avatar
I think it's helarious that people are jumping on this guy for calling his car an EM1, yet when people say they have an EK, no one says anything. For the record, OP, if you're in America, you probably have an EJ.
OP, you can run the Y7 harness, but you'll have to custom wire a few sensors, as well as the secondary O2. You'll have to get the HX O2 sensor, which is extremely expensive comparatively. Unless you're getting this motor for free, I honestly wouldn't put the time, money, and effort into the swap. You'll have a slower motor, a lot of money spent, and a lot of headaches.
Old Feb 12, 2012 | 09:16 PM
Marvin1985's Avatar
I'm betting this em1 is a Canadian si
Old Feb 12, 2012 | 11:08 PM
DCRB's Avatar
even if that were true it should still have a d16y8 in it
Old Feb 13, 2012 | 05:22 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
No....the canadian EM1 still had a B16A2 in it. They call those SI-Rs. For it to be an EM1, it has to be a north american 99-00 civic coupe with a factory installed B16A2. The Canadian Si is an EJ....it's like the USDM EX.
To the guy who asked why we're ragging on the OP for calling it an EM1: It's confusing why an EM1 ended up with a Y7....so that might change the answers to his question. The answers to the question also become very different if he actually has an EM1 since VTEC and the knock sensor is already wired in. Unless someone changed the harness? Either way...it's a source of some confusion. EM1 is also more specific than 'EK'. EM1 actually describes a very specific chassis. If you're going to use technical terms, you need to use them correctly.
OP: do you actually have an EM1?
jrgdog
Jan 21, 2011 08:25 AM
My JDM EJ8
17
Dec 19, 2008 06:08 PM
FRKWOO
Nov 30, 2008 07:34 PM
brusk13
Jan 11, 2006 02:51 PM
dogfood
Jun 5, 2004 12:03 AM
