97 lude no start helppp
Old Feb 11, 2012 | 12:19 PM
streetglowjoe's Avatar
Default 97 lude no start helppp
working on a 97 prelude, just swapped a h22a in it and now it wont get spark. however if i put any other ecu thats not from a prelude into it it will start but run like crap. so far we have replaced the coil dizzy and the crank sensor and ecus. and swapped out harnesses. this is really aggervating and any help would be appreaciated
Old Feb 11, 2012 | 09:05 PM
97ludedude's Avatar
Default Re: 97 lude no start helppp
Are you getting a green flashing key on your instrument cluster?
Old Feb 12, 2012 | 08:18 AM
IA95civicDX's Avatar
no he is not, also have tried 2 stock ecus.. it starts right up on a d16y8 ecu for some reason though or basically any ecu other than an stock automatic one that should be in it...
Old Feb 12, 2012 | 08:39 AM
do these ecu's ever need reprogrammed? i have never had to reprogram them in previous swaps on bb6's but im stumped
Old Feb 12, 2012 | 04:57 PM
5th_gen_lude's Avatar
how many miles??
Old Feb 12, 2012 | 04:58 PM
on motor n ecu
Old Feb 13, 2012 | 12:36 PM
97ludedude's Avatar
i was thinking maybe an immobilizer issue but if the green key is not flashing then problably not. Is the engine obd1 or obd2. I am assuming that if it is obd1 you did change the oil pump so that you have a crank sensor right? No it shouldn't need reflashing.
10minutecivic
10
Feb 24, 2011 06:21 AM
hondadw08
Feb 1, 2010 10:58 AM
darrinbrewer
Sep 8, 2009 07:50 AM
young geezer
Aug 2, 2009 07:07 PM
97preludetypeblk
Aug 13, 2006 07:27 PM
