98 civic ex has no electrical power
car was running fine, then the dashboard began to flash and the wipers started on their own. 80 amp fuse under hood was blown. i replaced it, now i have no power to anything. 80 amp fuse is still good. can anyone help
Check whether there is voltage on both sides of the 80A fuse. Also check the other big 40A and 50A hood fuses.
Do the headlights work? Have you cleaned and tightened the battery connectors and ground wire attached to the chassis?
nostreble
Jan 5, 2007 06:41 PM
