cel 43 fuel supply system, dont know were to start, help?!
Old Feb 10, 2012 | 12:55 PM
customrice's Avatar
Default cel 43 fuel supply system, dont know were to start, help?!
alright so i have a 92 civic dx with a d16y7 swap, and im getting a cel code 43 which is the fuel supply system. something thats happening is that my car will sometimes missfire between 1700-2000rpm but after that and before its fine, but it also doesnt do it all the time. what do you think it would be i have no idea were to start because "fuel supply system" is such a broad area. injectors, fuel pump? what? what do you guys think? help me?! thanks!
Old Feb 10, 2012 | 04:06 PM
customrice's Avatar
Default Re: cel 43 fuel supply system, dont know were to start, help?!
140 views? anyone know?
Old Feb 10, 2012 | 05:59 PM
customrice's Avatar
bump.....
Old Feb 10, 2012 | 06:03 PM
grumblemarc's Avatar
The Grumpiest
CELs?
What have you done so far?
Here's one of the threads I found when i s-e-a-r-c-h-e-d.
https://honda-tech.com/forums/tech-misc-15/code-43-seriously-pissing-me-off-1717065/
Old Feb 10, 2012 | 06:28 PM
customrice's Avatar
yes cel 43 fuel supply system, and yes ive searched ive already gone through that thread and another one but they dont seem to have an answer. and i dont want to just start dumping money into random things that may not even be it. i wouldnt think it would be the o2 sensor mainly because why would that cause my car to misfire?
Old Feb 10, 2012 | 06:44 PM
Former User's Avatar
Measure the fuel pressure, test the FPR, and check for dirty/clogged fuel injectors.
It might also be worth checking whether unplugging the primary O2 sensor eliminates the problem.
Old Feb 10, 2012 | 06:55 PM
customrice's Avatar
alright thanks, ill try that out tomorrow morning, hopefully thatll fix my problem
Old Feb 10, 2012 | 08:35 PM
Tim1982's Avatar
It could be the injectors. I had some do the same same thing
Old Feb 12, 2012 | 07:11 AM
customrice's Avatar
alright so im kind of new at this, and yes ive searched but all i get is a bunch of random threads, how do i remove my injectors?
Old Feb 12, 2012 | 07:31 AM
The Grumpiest
Remove the fuel rail.
Old Feb 12, 2012 | 07:38 AM
customrice's Avatar
thanks, and thats it? and they just pretty much slide right out?
Old Feb 12, 2012 | 08:45 AM
Old Feb 12, 2012 | 09:35 AM
apexi_rsx's Avatar
I clean mine by hooking the injector up to a battery box at regular charge and spray carb cleaner through it. then i disconnect the injector spray sum carb cleaner in the top to hold it then taking an air hose with 30psi to it and reconnect the injector and stray it through and watch the pattern.
Old Feb 12, 2012 | 10:26 AM
customrice's Avatar
thanks for the help, but i am going to retry this tomorrow now because i have to go to work soon, and i just noticed that my far left injector (when viewing the engine) is leaking fuel, so theres another problem. hopefully ill be able to fix all of this up tomorrow
Old Feb 13, 2012 | 01:16 PM
customrice's Avatar
alright so ive got everything pulled out and, i found something in the top of only one of my injectors and i dont know what it is, or really why its there, but i took some pictures to show you guys
http://m1175.photobucket.com/albumvi...%2BM8wHcrJE%3D
sorry for some reason it doesnt work for me to put the pictures on here from photobucket, but here are the links to the three pictures that i took. Its that blac "cap" type of thing in the left injector. and in the last picture i pulled it out to take a pic of the whole thing. but my question is, is what is that? is it supposed to be in there? because that is only in one of the injectors and its not in any other one.
Old Feb 13, 2012 | 02:17 PM
customrice's Avatar
bump... anyone know?
Old Feb 13, 2012 | 06:24 PM
customrice's Avatar
alright nevermindi found out that its a injector fuel filter, and im missing three of them.... haha would that cause it to misfire?
91blackEF
Apr 5, 2021 03:23 PM
Tru3Sav
Jul 28, 2008 09:29 AM
shivic
Apr 23, 2004 11:20 AM
degooser
12
Apr 23, 2003 05:16 AM
