CEL 43, FUEL DELIVERY SYSTEM Help!!!!!!
Old Apr 21, 2004 | 08:33 AM
shivic's Avatar
Default CEL 43, FUEL DELIVERY SYSTEM Help!!!!!!
hey guys, i need help. my car throws fuel delivery system cel.
if the car idles for 2 minutes, it sounds like it drops a cylinder, runs real rough and throws cel 43.
i have a turbo eg, greddy piggyback, chipped p28, stock fuel pressure, big fuel pump.
Can a pickup falling off the fuel pump cause this. Or do you think its electrical.
Old Apr 21, 2004 | 09:06 AM
tegasaurus's Avatar
Default Re: CEL 43, FUEL DELIVERY SYSTEM Help!!!!!! (shivic)
sounds like electrical and something with the injectors judging by how you think its dropping a cylinder (which it probably is).
Old Apr 21, 2004 | 10:22 AM
TurboBumblBee's Avatar
Default Re: CEL 43, FUEL DELIVERY SYSTEM Help!!!!!! (tegasaurus)
ive gotten that code before and actually just got it the other night.. i was playin around w/ an STI and it came on.. i turned the car and the code went away and has not come back yet.. someone in the NA forum said it can also come on if your car is running too rich..
Old Apr 21, 2004 | 11:16 AM
hoggy's Avatar
Code 43 gets thrown when the ECU has to correct more than a certain percentage to get the o2 sensor to fluctuate correctly.
I've had it come on for two reasons. One was a bad o2 sensor. The car was seeing lean conditions from the o2 sensor so it was dumping more fuel than necessary to get to what it thought was stoich.
Second was the fuel map was way too rich and the ecu couldn't correct enough so it threw a code 43. When it came on for me I could just turn the key off and back on real quick and it would clear the code. This may not be the case for you as your car may have a lot worse problems than mine did.
Old Apr 22, 2004 | 05:52 PM
Default Re: (hoggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy &raquo;</TD></TR><TR><TD CLASS="quote"> When it came on for me I could just turn the key off and back on real quick and it would clear the code. This may not be the case for you as your car may have a lot worse problems than mine did.</TD></TR></TABLE>
did the same things for me.. i turn the key off every time and it goes away.. still would really like to know why it does it tho.. kinda odd..
Old Apr 22, 2004 | 05:55 PM
GSR619SD's Avatar
I'm getting the same code, I think mine is due to a loose wire on my o2 sensor. I've just been too lazy to try and fix it.
Old Apr 22, 2004 | 07:00 PM
V-SPEC 1's Avatar
Default Re: CEL 43, FUEL DELIVERY SYSTEM Help!!!!!! (GSR619SD)
I replaced my o2 and went away.
Old Apr 22, 2004 | 07:44 PM
D@nnY's Avatar
usually an o2 sensor..also could be the fpr
Old Apr 22, 2004 | 08:32 PM
MikeMAN's Avatar
Code 43 is fuel system to lean or rich, got it when i went b20vtec with stock injectors, i raised the FPR a few psi..and perfect. However, it doesn't tell you weather or not you are lean or rich.
mike
Old Apr 22, 2004 | 09:19 PM
V-SPEC 1's Avatar
Default Re: CEL 43, FUEL DELIVERY SYSTEM Help!!!!!! (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">Code 43 is fuel system to lean or rich, got it when i went b20vtec with stock injectors, i raised the FPR a few psi..and perfect. However, it doesn't tell you weather or not you are lean or rich.
mike</TD></TR></TABLE>
get a wide band 02 sensor
Old Apr 22, 2004 | 09:30 PM
MikeMAN's Avatar
Default Re: CEL 43, FUEL DELIVERY SYSTEM Help!!!!!! (boostedb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">
get a wide band 02 sensor </TD></TR></TABLE>
or have someone with a code scanner scan it quick for free ( i did) and it will tell you if its lean or rich
mike
Old Apr 22, 2004 | 11:11 PM
D@nnY's Avatar
actually 45 is to rich to lean 43 is fuel system supply..we can only put hte honda scanner on it if its obd2..there might be another scanner for obd1 im not sure
Old Apr 22, 2004 | 11:15 PM
Vtec92Civic's Avatar
Default Re: (D@nnY)
I use to get code 43 ll the time, and from time to time Is till do get it. I don't think I got it when I was NA in between turbo setups. My car does not feel like it drops a cylinder, it still seems like it runs fine . . . it does however drop the idle because of the ecu dumping more fuel I believe.
I baught a new o2 sensor and have not yet seena code 43
Old Apr 23, 2004 | 10:56 AM
shivic's Avatar
Default Re: (hoggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy &raquo;</TD></TR><TR><TD CLASS="quote">Code 43 gets thrown when the ECU has to correct more than a certain percentage to get the o2 sensor to fluctuate correctly.
Second was the fuel map was way too rich and the ecu couldn't correct enough so it threw a code 43. When it came on for me I could just turn the key off and back on real quick and it would clear the code. This may not be the case for you as your car may have a lot worse problems than mine did.</TD></TR></TABLE>
thanks for the insight, im going to try the o2 sensor first.
Old Apr 23, 2004 | 11:20 AM
project dc2's Avatar
Default Re: (shivic)
BTW also check yoru gas cap is on tight
Tru3Sav
Jul 28, 2008 09:29 AM
218luder
Sep 1, 2006 06:04 PM
nate10498
Apr 10, 2006 08:54 AM
shivic
Apr 23, 2004 10:52 AM
DC2EGHB
13
Mar 18, 2004 05:44 AM
