HELP: LST setup wont rev past 3500rpm..
Old Feb 10, 2012 | 06:54 AM
ThrowSomeDs's Avatar
Default HELP: LST setup wont rev past 3500rpm..
Ok so last night I was driving my 97 Integra (not like an ***) and the car started misfiring and I could tell one cylinder wasnt firing. So I got the car home, played with it this morning and got it to fire on all cylinders.
(stupid injector plug had no clip on it)
Now with that fixed, my issue is my car wont let me rev past 3500rpm. It seems to be in some sort of limp mode....Here are the mods and hopefully someone can help me out? Is it in limp because of a misfire code?
Maybe disconnecting the battery for awhile will reset the issue?
Stock LS
Tuned on Neptune 5.8psi
.50trim Turbonetics t3/t4
Drag manifold
Knock off waste gate
ARP headstuds
Drag intercooler
Blitz bov
OBD2-1 jumper harness
(ECU is unknown because I got the car this way and the markings have since been removed)smh
Old Feb 10, 2012 | 06:58 AM
kyden's Avatar
Default Re: HELP: LST setup wont rev past 3500rpm..
do you have a check engine light on?
Old Feb 10, 2012 | 07:02 AM
yea but its been on. Only had the car for a few weeks and I havent really been able to jump it to see what the light was on for in the first place. But it ran fine before this.
Old Feb 10, 2012 | 07:15 AM
kyden's Avatar
well common sense would dictate you check it when you are having an issue.
Old Feb 10, 2012 | 08:38 AM
Turbo-LS's Avatar
not completely familiar with neptune but i would assume it has a way of checking CEL codes like yuo can do with hondata s300
Old Feb 10, 2012 | 10:48 AM
techtuner's Avatar
you can also hook it up to an obd2 scanner. go to o'reilly or autozone and tell them to scan it for you.
Old Feb 10, 2012 | 11:04 AM
kyden's Avatar
no you can't. it's on neptune, which is obd1.
Old Feb 10, 2012 | 11:12 AM
Builda'Teg_92's Avatar
You could also check your jumper harness. A buddy of mine was having the same problem until one day we took it around the block, i stepped on the harness by mistake and all was solved. It was a no name brand. Probably wont be the cause, but it can happen.
Old Feb 15, 2012 | 08:54 AM
jdm-allstarz's Avatar
Check TPS sensor. It might be bad. Had same issue with my gsr. Swap out the TPS and ran like a champ!!
Old Feb 15, 2012 | 08:56 AM
Dc4LsTeG's Avatar
EK9
Start by checking your cel
Granny_shifter
18
Sep 17, 2012 08:08 AM
Eg_mE
May 23, 2009 03:34 PM
EK 2 9K
Sep 2, 2007 05:40 AM
