1986 corolla gts coupe ae86
Old Feb 10, 2012 | 12:00 AM
jdm_dk's Avatar
Default 1986 corolla gts coupe ae86
1986 Toyota Corolla GTS (AE86 Kouki Sprinter Trueno) $5500 (951) 836-5705 NO TRADES.
Clean Title & Registration up to date
WHEELS / BRAKES / SUSPENSION
-XXR 513 15x8, 0 offset
-Rx7 TurboII calipers custom Bracket <br>
-Mini Copper S rotors (front)
- Brembo Cross-Drilled Rotors rear
- Rebuilt Brake Calipers (rear)
- 300zx TT Brake Master Cylinder
- Brake Proportioning Valve
- Braided Brake Lines
- Megan Racing Coilover Damer kit
- Spring Rate 8kg front & 6kg rear
- Spindles welded on by JSP Fab
-New wheel bearings
-T3 Rear 4 Link
-T3 Adjustable Panhard Bar
-rebuilt manual rack with T3 adapter bushing, ueo style inner & outer tie rods
TRANSMISSION / DRIVELINE / DIFFERENTIAL
-New Speedo gear
-Cusco Transmission Mount
-New Clutch Master Cylinder & Slave Cylinder
-Stage 2 Clutch Assembly
-Light chromoly Flywheel
- Weir Performance full spool kit w/new bearings not installed
-Stock LSD
-Walbro fuel pump
ENGINE / EXHAUST
-Rebuilt 4AGE 7 Rib with oil squirters, Shaved Head, Valve Job, light porting of the head
- New Oversized Factory Pistons & Ring Set (0.5 over)
- New ACL Race Bearings & Thrust Washers
-TRD Metal Head Gasket 0.8mm
- New Engine Factory Metal Gaskets kit, No paper gaskets
- Toga High Flow & pressure Oil Pump
- Ksdengineering.com DG Wercs IACV Blockoff Plate
- Cusco Engine Mounts
-HKS Cone Air Filter System
-PBS Header Assembly
-Megan under diff Exhaust System with HKS Hi-Power Exhaust Muffler
-T3 Straight Pipe Assembly
INTERIOR
-Nardi Steering Wheel
-Boss Kit (specific for AE86)
-Nrg Quick Release
-Oversize Drift E-Brake Button
Old Feb 10, 2012 | 07:02 AM
Ayee_drian's Avatar
Default Re: 1986 corolla gts coupe ae86
Dope
Old Feb 10, 2012 | 08:10 AM
RoTb TwEaK's Avatar
I want this as my daily!! Damn ae86!!beautiful
Old Feb 10, 2012 | 08:13 AM
skateboard_ej8's Avatar
im hench irl
Nice, bump for you.
Old Feb 10, 2012 | 08:43 AM
Blah.'s Avatar
DRIFTTTTT!!!
Old Feb 12, 2012 | 03:39 PM
jdm_dk's Avatar
Thanks guys!
Old Feb 12, 2012 | 06:26 PM
Black-Ty [EG6]'s Avatar
nice
Old Feb 12, 2012 | 07:18 PM
EG9b20vtec's Avatar
Bump
Old Feb 12, 2012 | 09:38 PM
dragon909boi's Avatar
beautiful
Old Feb 12, 2012 | 09:56 PM
aftermath1312's Avatar
Gts
Bump for you
Old Feb 13, 2012 | 07:12 AM
artiecubz's Avatar
Old Feb 14, 2012 | 07:12 AM
civic nation's Avatar
nice car. drift ready
Old Mar 15, 2012 | 11:42 AM
Lancer07's Avatar
Do you still have the ae86?
Old Mar 23, 2012 | 03:01 PM
ank009's Avatar
Wish u were closer... Would've bought this....
Old Mar 23, 2012 | 03:06 PM
DO/\/\O's Avatar
Dk!
CarBug
Jun 12, 2016 01:51 PM
raverx3m
Suspension & Brakes
16
Jan 2, 2013 08:51 PM
jdm_dk
Jun 19, 2011 02:57 PM
X2BOARD
58
Nov 7, 2003 12:58 PM
Holden
Sep 23, 2002 07:24 AM
