Sticking Brake Caliper
My driver's side rear caliper is sticking. I think I need a new caliper, but hope you guys can clue me in.
The facts:
- Sliders slide fine
- Ebrake works fine
- Pads are not stuck
- Piston is aligned with pad properly
- Piston rotates. It was sticky at first, but rotates freely after a little turning.
- Brakes work fine
So do I get a new caliper or what?
Thanks in advance.
The facts:
- Ebrake works fine
- Brakes work fine
Thanks in advance.
It's only the driver's side rear caliper that sticks.
I haven't bled this one since spring, but I don't see what difference that makes. Fluid was changed 1000 miles ago. SS lines and speed bleeders installed then too. Brakes work fine. Master cylinder is fine.
It's not the bearings. The wheel spins freely once the brakes are removed.
projekthonda02
Suspension & Brakes
Apr 15, 2012 03:13 PM
Arvid
13
Aug 4, 2004 03:34 PM
X2BOARD
58
Nov 7, 2003 12:58 PM
