biggest injectors on a chipped ecu
i been searching but can find an answer, i was wondering whats the biggest injector size i can run on a chipped p28 on chrome i think(not sure what my tuner is using but it will be on the dyno). someone told me that if i go higher than 1000cc i need hondata. my setup will be a stock b16a turbo and wanting to hit around 380whp on E85 and i dont wanna have to buy a hondata ecu. sorry for the long post...thnks guys
you don't need higher that 1000cc injectors for that application. But you do need to build your engine or you're going to destroy it if you're targeting 380hp.
Hondata is not an ecu. It is an EMS that is used for tuning just like Crome but better by far. Same with Neptune. They are better than Crome ever was or will be.
Hondata is not an EMS. It's a ROM editor. And that's not true, although Crome IS buggy for those who aren't tech savvy, I can tune any car with either application equally as well.
Crome's only problem is John Cui got lazy and greedy. If he had kept up on it, it'd be a hell of an editor by now.
You can run Injector Dynamics 2000cc injectors with a chipped p28 & the car will idle like stock if properly tuned :-)
Do your self a favor & buy high impedance injectors like Injector Dynamics, Deatschwerks, FIC.
Also consider using a better romeditor then crome such as Hondata, Ectune or Neptune etc.
BoostedH23a1
Jun 26, 2003 03:32 AM
