z6,with 2000 y8 mf turbo iddling problem help asap
hey guys i have a 97 ek sedan ex i swapped a z6 with a 2000 manifold just end it up finding out that it has a cold start vacume hole or some **** ,,umm the manifold i used the same gasket that it had bad idea i know so at first i didnt put water to start it ,i cranked it i saw that it turned on ,great turned it off again ,i put water in it and turned it on ranned great , i ent around the block quick and came bak i parked it i try turning it on again and it started after like 20 seconds of me holding the ignition like if it had a blown head gasket ,witch it DOESNT ,i hear a sizzling noise between the intake manifold and the head ,i tought it was the injectors ,i checked in back of the intake manifold and i see that water is running out of the intake manifold ,by the dizzy by the way , when i look at d turbo i see like water getting splashed out the exaust housing but the car is iddling like **** now ,i checked the oil and it has water in it ? could water be getting in the intake manifold and making it run like **** ? help
I have to quote this for posterity.
WTF are you saying? You ranned it? You ran what without water? You put water in what? Where? Oil has water in it? Are you really meaning WATER and not coolant? Are you typing this on a phone?
Did you have water in the oil before the manifold?
Like you said you have a 00 manifold with the cold start assist valve on it, it needs to be plugged.
As for the water in oil, I doubt the manifold has anything to do with it.
mayb it had a lil bit of water idk it was used oil,but the sputtering is really bad and water is coming out of the exaust turbine .so im pretty sure water is getting ointo the manifold
dude if ur not gonna help me and just critizieze the way i talk than **** off ,damm i hate people that do that ,help me ,dont help me how to type
Trying to. No one understands anything you've posted because of the bad grammar and spelling. It makes it difficult, if not impossible, to follow you. As a matter of fact I'm searching the internet for a fix or similar thread.
im not trynna be a dick but damm work with what i have posted it but yea picture is raining right now but what im guessing the water is gushing out of is by were the water runs thru that round hole that it has in the intake manifold ...why would my turbo throw out water ?? and it sounds like if it had water in the gas but it doesnt i went n put new gas 93 octaine on it
Also, is there any reason you aren't using the Z6 manifold? Paraphrasing from someone I trust "All the Y8 one will do is shift the powerband around and make cylinder #3 run lean".
yo here is the pics
its under those holes right under the injector fr cylinder 4
this is to see if i conected the wiring right
this is goes here
i cant remeber now were they all go but if you can tell me ill be better
im using a y7 dizzy for now it might be of timing but check it out
this is how rich is running
idk i cant remember
this is goes here
idk i cant remember
not that useful cause but idk mayb they could help ..were i think water is passing by or leaking thru is that round hole in the intake manifold right by the injector # 4 idk man
also i seen that u might have to do some changes to the ecu pins i have a 97 and i put a z6 do i have to do nething to it wiring wise ..help me please
Sorry man. I cannot see anything in those pics. Right now I'm thinking you have something swapped. I couldn't find anything where someone has done such a swap and had this issue.
Are you serious? Who ever did your swap is an idiot, you clearly have no right having a turbo vehicle your going to hurt yourself And more importantly somebody more important. Your running a z6 with a Y8 manifold, with a p75. Get a chipped ecu and have a basemap installed and get it to the closest reputable shop. Your not qualified to speak English or work on anything except your english.
First time I've heard about a P75. I know you tried to start another thread and only mentioned it there for the first time.
Well it's going to run like crap if it's an OBD2 P75 like you said. Why do you think you can run a dual cam non-VTEC ECU on a VTEC single cam?
Your turbo build is highly questionable as well but I still think you somehow have hoses mixed up.
Why are we not running a Z6 manifold?
