93 hatch dash light issue. Help?
Old Feb 8, 2012 | 08:55 PM
SKAVENGER88's Avatar
Default 93 hatch dash light issue. Help?
I have running lights and headlights. But no dash lights. I think it might be the switch. I just bought it and it's has a b16 in it would that have anything to do with the persons wiring before me. Thanks.
Old Feb 9, 2012 | 06:35 AM
Jdubbs6101's Avatar
Default Re: 93 hatch dash light issue. Help?
It's your dimmer switch they are garbage in the EG chassis. You can try to take it out and spray it with WD-40 or LPS but chances are it needs replaced. If you search there might be a thread to fix what ever component is prone to failure on those and fix it yourself.
Old Feb 9, 2012 | 06:48 AM
Jdmbryan's Avatar
or a fuse under the dash
Old Feb 9, 2012 | 06:53 AM
freshCROOKS's Avatar
i had the same problem. it was a fuse and it kept popping. i just used amp wires and wrapped it around the fuse so it wont pop (not recommended btw). i sold my car not too long after. never fixed it. assuming theres a short somewhere but at the time i was lazy to check.
Old Feb 9, 2012 | 08:28 AM
Saggio's Avatar
Pull the plug out of the dimmer and jump a wire between the red and black wire.
Bypass the dimmer basically.
Old Feb 9, 2012 | 01:47 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Yeahhhhhhhh... whatever you do, OP, ^^^DON'T DO THIS ^^^^
Old Feb 9, 2012 | 02:06 PM
NVturbo's Avatar
O.G. triple O.G.
Does it have an aftermarket radio? If so, check the wire connections. That's a common problem since the radio cavity is very tight and doesn't allow any room for the allocation of the wires behind the radio itself.
Old Feb 9, 2012 | 02:12 PM
heavens_gift's Avatar
sounds like the dimmer is bad i would suggest the same thing saggio said.
Old Feb 13, 2012 | 12:12 PM
Ok I'm going to change out the dimmer next. The thing is this cars wiring is jacked up previous owner raped the wiring. Come to find out it looses power within a couple day of sitting. I'm thinking it's a security system draining the power. I'm going to rip that out and cuz the only thing it's good for is power unlock. I did change the turn signal switch and the cluster. But now I have a cluster problem. It use to be a d16 automatic and now it's a b16a2 Manual. It was swapped when I bought it so I changed out the cluster and the tach doesnt work and the last one had no tach
Tito559
Jan 27, 2011 03:27 AM
93WhiteHatch
Jul 26, 2006 02:01 PM
CRXsiproject
Oct 19, 2005 12:15 AM
plusONE DC2
Dec 10, 2004 05:10 PM
9000rpms
Nov 22, 2004 12:48 PM
