EG Coupe w/ B16A throttle issue
Old Feb 8, 2012 | 08:43 AM
NEEDBOUTTREE5O's Avatar
Icon3 EG Coupe w/ B16A throttle issue
The car fires right up, idles smooth, and sounds great. However, when I press the pedal to around 1-2k, keeping the pedal in the same position, the engine speed varies 1-2 hundred rpm. Not only does thsi happen when I'm sitting still but also when I'm moving, causing the car to jump, and jerk like it's about to stall. If I adjust the TPS sensor it fixes it, but only temporarily. Any help will be greatly appreciated.
Old Feb 8, 2012 | 08:48 AM
6000pounds's Avatar
Default Re: EG Coupe w/ B16A throttle issue
Not sure if this helps or not but I had the same problem on my pickup truck. I swapped out the TPS sensor and it fixed it slightly. Turns out it was the wiring to the TPS sensor that was the problem.
NEEDBOUTTREE5O
Feb 10, 2012 02:42 PM
mokers
Jun 1, 2011 08:49 PM
ryanhauk
17
Jan 24, 2010 12:35 AM
shamoo
Dec 30, 2002 12:16 PM
DKay04
Jun 28, 2002 01:31 AM
