k20a3 clutch and flywheel to k20a question
i have a jdm k20a type r motor in my rsx but it has a ep3 transmission because the previous owner was going to boost it so my question is if i get a type s transmission will i be able to use the clutch and flywheel off of the a3 on my type r??? thanks in advance
no the a3 anf the base modle rsx are compatible but theres no point in investing money for labor and having down time in replacing it with an a3. if you really are running a type r you should try to upgrade the trans is possible the a3 trans is trash. and not all k clutches are the sam either or compatable in his case he can only use the base mode rsx other than the a3
honsetly the best thing for you to do is upgrade to a rsx-s flywheel either oem or lightened and use the rsx-s clutch way better than the a3 and base modle. !!!!!!!!!
mitcho
10
Dec 4, 2012 03:43 PM
Gunmetal_B20_Hatch
Jul 14, 2005 09:35 AM
