97 CX manual conversion/wiring
Old Feb 7, 2012 | 06:42 PM
Fliptard's Avatar
Default 97 CX manual conversion/wiring
ok, I KNOW that you are all going to tell me to do research, but I don't have time to sit here and search and read for hours. I have done some searching but can't find a straight answer.
I have a 97 CX auto that I am converting to Man, with an OBD1 B18B1 w/ ex engine harness. Eventually I want to convert everything to manual, doors, mirrors and all that good stuff.
So Instead of cutting and splicing wires, would it be much easier to just get an EX cabin/floor harness? And does that have all the plugs and everything I would need to be able to just put the power doors on and just plug in and go? As well as the fuse box, relays and all that stuff?
Old Feb 7, 2012 | 08:05 PM
Fliptard's Avatar
Default Re: 97 CX manual conversion/wiring
100 views and no simple answer
Old Feb 7, 2012 | 10:55 PM
Fliptard's Avatar
bumpp
Old Feb 8, 2012 | 04:38 AM
94EG8's Avatar
Seagull Management
If by manual windows/locks you meant power than yes. get a '96 - '98 EX cabin harness, door harnesses and engine harnesses. Ideally get it from a 5 speed car and you wont need to do any additional wiring for the auto to manual swap.
Old Feb 10, 2012 | 03:52 PM
Fliptard's Avatar
Awesome. That's all I needed to know, Thanks!
Old Feb 10, 2012 | 04:37 PM
canadaek's Avatar
the dash harness is different between an auto trans and manual trans the floor harness is the same
Old Feb 10, 2012 | 04:50 PM
Fliptard's Avatar
So the plug for the auto shifter is on the Dash harness then? And isn't the floor harness different between a car with power doors vs manual doors?
Old Feb 10, 2012 | 08:47 PM
NotAJDMFanBoy's Avatar
I know on the 5th gen the plug for the auto shifter is part of the dash harness. You can just connect two wires to make the car think it's in park all the time, or wire up a clutch interlock switch. The interlock box just unplugs and your key can come out of the ignition anytime you want.
To convert to manual windows and locks etc, just remove the power parts and bolt in the manual ones and covers. I'm curious what the weight savings really is for the power window regulator compared to the manual regulator.
Old Feb 11, 2012 | 06:19 PM
canadaek's Avatar
yes the floor harness is different between manual windows,mirrors,locks and one with power. also if you have a rear wiper you will have to add the wire for it to the coupe harness
Red82
Honda CR-V & Element
Dec 9, 2018 12:47 AM
Registered user
Sep 5, 2016 08:01 AM
Cap'N Chronic
Jul 14, 2012 03:01 AM
EKCivicGirl
Mar 21, 2011 06:58 PM
b20vtecEK
May 3, 2004 11:12 PM
