ls/vtec or poor mans type r?
Old Feb 7, 2012 | 03:14 PM
jarhead90crx's Avatar
Default ls/vtec or poor mans type r?
I have almost all the stuff to do an all stock ls/vtec swap into my crx but now I have the opportunity to do a poor mans type r with a port and polished b16 head, dual springs on both sides and a gsr block with eagle rods and oem valves and b16 pistons.
I was told an all stock ls/vtec swap has more horse and torq than a poor mans type r but the poor mans type r is a stronger more dependable setup.
Opinions or comments on which one should I do?
Old Feb 7, 2012 | 03:34 PM
DirtyDA9's Avatar
Default Re: ls/vtec or poor mans type r?
If you actually take your time to build the LSV right (everything in spec) and use ARP rod bolts and such, it will be just as reliable as any PMTR.
Old Feb 8, 2012 | 07:42 AM
HOMEMADEPOWER's Avatar
To me anyway you decide to go ls vtec or poor man type r and you build the motor right you'll be fine bro.
Old Feb 8, 2012 | 08:59 AM
93egSLEEPER's Avatar
The extra displacement of the LSV will give you a hair more TQ and the ability to make more power easier. "There's no replacement for displacement" Either motor will be a nice build.
Old Feb 8, 2012 | 08:48 PM
ghost14's Avatar
i would go either way cuz its goin into a rex
Old Feb 9, 2012 | 10:35 AM
95 integra's Avatar
GSR block is stronger than a LS block due to the extra webbing it has. As far as a LS crank or GSR crank, honestly it doesnt make much difference. The LS rod bearings are wider, which leads to more friction which is always a concern to myself...however I have revved them to 9k problem free in the past.
Farmer89511
14
Mar 19, 2009 08:05 PM
JDMeman
Mar 21, 2008 02:53 PM
iNTEGRA-vibe
Jun 18, 2004 12:19 PM
99lsvtecauto
Nov 16, 2003 03:09 PM
projectTeG
Sep 28, 2003 12:34 PM
