Brake Booster Pin Pivot Removal after the fact
Old Feb 7, 2012 | 02:38 PM
will46r's Avatar
Default Brake Booster Pin Pivot Removal after the fact
Searched, read through 8 pages of threads on brake boosters and can't find this exact answer.
Replacing the brake booster on my 90 Civic STD. Already got the 4 nuts of doom and the pivot pin removed but can't get the pivot removed from the booster. I can't remove it from the engine bay because the pivot is hanging up on the opening. It would be a simple removal except for that one issue. I'm really confused by this. I've never had this issue on my other cars but I am new to Hondas.
Yes, I have removed my master cylinder.
Yes, I have removed every hose and line I can see in the way.
No, I don't know what else to do. I have really fat hands and arms and probably should stick to working on large V8 trucks where I can sit in the engine compartment and work on the vehicle.
Old Feb 7, 2012 | 03:19 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Brake Booster Pin Pivot Removal after the fact
Might help
#13 and #18 are for SURE removed? or did you maybe put them back on for safe keeping?
Old Feb 7, 2012 | 03:35 PM
will46r's Avatar
4Dr
Yes, 13 is removed and sitting in my little parts thing. #2 is hanging up in the opening. I've twisted, turned and cursed at the whole thing with no effect. I've jammed a long screwdriver in it in an attempt to compress it enough to remove.
I can't get a wrench on to hold the shaft so I can try to loosen the star lock nut. I may put the sawzall onto the shaft and remove it like that. It's only a $20 core charge.
Thank you.
Old Feb 7, 2012 | 03:58 PM
4drEF's Avatar
Keyboard Humorist
It's been a while since I have did a booster swap, but I think #16 is a jam nut.
Maybe hold onto that with a wrench and then twist #2.
Old Feb 7, 2012 | 04:03 PM
will46r's Avatar
I'm seriously thinking sawzall the shaft and let it run...
Old Feb 8, 2012 | 10:24 AM
will46r's Avatar
The pivot thing was assembled with Loc-tite Red... had to put it in the bench vise to remove it.
In case anyone wants to know my solution to this problem.
I used a small pry-bar to take the booster apart, pull the halves out then reassembled for my core charge.
Old Feb 8, 2012 | 11:30 AM
wanabebuff's Avatar
Nice info, thanks for actually following up on your thread and posting the solution to your problem. I will be removing my booster soon and replacing it as well, hopefully mine will be a little less painful.
Old Feb 8, 2012 | 11:44 AM
will46r's Avatar
I don't think it was originally assembled with loc-tite because this is a part made to be adjusted and it is fixed with the pivot pin and cotter pin and the loc-tite was slathered all over the place.
gabebauman
Suspension & Brakes
Jul 24, 2009 12:23 PM
gophat
Dec 26, 2006 05:53 PM
mixmastabob
Dec 7, 2006 12:09 PM
MNCRXSi
Nov 1, 2006 06:49 PM
tmitbyh
May 22, 2006 06:06 PM
