Help with tial wastegate
I have a drag turbo kit for my 2000 honda accord. The problem is that I'm only boosting 3 psi. So I'm guessing that the wastegate is not hooked up right. So can someone tell me how to hook up the wastegate. I'm not sure which one it is but it was the upgrade tial wastegate from import parts.
check all of your charge pipes...one might have blown a little off, preventing you from boosting to your full potential.
[Modified by B18EG6, 4:11 PM 10/9/2002]
I checked all my pipes and they are fine.
The next question is will I have vac lines going to both ports on the wastegate or just to the port on the side?
have the vac line come out the one on the side. The top port is for an electronic boost controller, and if you arent using one then leave it open. If you are using a manual boost controller, use the vac line on the side.
Cowboy
Jun 17, 2003 01:17 PM
