Help with tial wastegate
Old Oct 9, 2002 | 12:09 PM
dragtaccord's Avatar
Default Help with tial wastegate
I have a drag turbo kit for my 2000 honda accord. The problem is that I'm only boosting 3 psi. So I'm guessing that the wastegate is not hooked up right. So can someone tell me how to hook up the wastegate. I'm not sure which one it is but it was the upgrade tial wastegate from import parts.
Old Oct 9, 2002 | 12:11 PM
B18EG6's Avatar
Default Re: Help with tial wastegate (dragtaccord)
check all of your charge pipes...one might have blown a little off, preventing you from boosting to your full potential.
[Modified by B18EG6, 4:11 PM 10/9/2002]
Old Oct 9, 2002 | 12:15 PM
Etylorcen's Avatar
Default Re: Help with tial wastegate (B18EG6)
Are you sure your wastegate is down tight? It might be loose...check your charge pipes too.
Old Oct 9, 2002 | 12:25 PM
Default Re: Help with tial wastegate (Etylorcen)
I checked all my pipes and they are fine.
The next question is will I have vac lines going to both ports on the wastegate or just to the port on the side?
Old Oct 9, 2002 | 12:26 PM
B18EG6's Avatar
have the vac line come out the one on the side. The top port is for an electronic boost controller, and if you arent using one then leave it open. If you are using a manual boost controller, use the vac line on the side.
Old Oct 9, 2002 | 05:40 PM
accordfreak's Avatar
mine does the same...boost controller fixed that.
Cowboy
Jun 17, 2003 01:17 PM
blu_si
Oct 1, 2002 04:20 PM
B18C4-T
Jun 29, 2002 01:14 PM
whagkangmakulet
Oct 1, 2001 11:34 AM
