95 cx - should I swap the engine or fix the head gasket?
Old Feb 6, 2012 | 07:59 PM
nerospy's Avatar
Default 95 cx - should I swap the engine or fix the head gasket?
hey guys I just picked up a 95 cx hatch for a few hundred, its runs but I think the head gasket is blown. It leaks oil and smokes from the lower part of the motor. Question is it worth it to swap another motor in it or should fix the gasket. And generally how much to swaps run
Old Feb 6, 2012 | 08:04 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: 95 cx worth a swap?
buy a jdm engine for 300 bux.
Old Feb 6, 2012 | 08:06 PM
Zidane6894's Avatar
I would say fix it if its just the Head gasket and nothing else majorly wrong with the engine/transmission. Its really not that hard or expensive to replace a head gasket in these engines.
And as far as a swap goes it depends on what engine you wanna swap in really.
Old Feb 6, 2012 | 08:11 PM
Dead CIVIC's Avatar
Veteran: Army
well. if you can do the work yourself, the Zidane6894 is right. but also if you just buy a nice d15b and throw it in there is wont be too expensive either. and youll be MaD JDm BRAH.
Old Feb 6, 2012 | 08:22 PM
nerospy's Avatar
its seems to run fine I have seen rebuild d16y motors for around 900 on craigslist but I'm pretty new at this didn't want to drop the cash if its going to take more cash on top of the motor
Old Feb 7, 2012 | 01:32 AM
HondaPartsHero's Avatar
Technical Hero
junkyard, pretty much any SOHC d-series engine will bolt in. How many miles on the current engine?
Old Feb 7, 2012 | 06:14 AM
nerospy's Avatar
Default Re: 95 cx - should I swap the engine or fix the head gasket?
there are 160000 on the car. The lady i bought it from said it had been rebuilt at some time.
Old Feb 7, 2012 | 06:23 AM
grumblemarc's Avatar
The Grumpiest
And this has what to do with the head gasket going out, bad rings or any of the other problems the car is exhibiting? Doesn't sound like it was rebuilt recently if it even was.
Your route is pretty clear. Which of your options costs the least amount of money to follow through on? (Once again) This isn't a tech question. It's a finance question.
Old Feb 7, 2012 | 06:34 AM
nerospy's Avatar
Originally Posted by grumblemarc
And this has what to do with the head gasket going out?
Well see the question was is it worth it to replace the head gasket on the car or just better to replace the whole thing. (Once again) thanks for your input.
Old Feb 7, 2012 | 06:40 AM
The Grumpiest
Worth=cash and/or time. Is it more expensive to fix the current deficiencies with the engine or buy a new engine and have it put in? How is this NOT a finance question?
And don't think replacing a headgasket is going to stop your smoking or oil leak issues. You have other problems that you haven't even diagnosed yet. Did you even do a leakdown or compression test on the engine? Nope. You're just guessing it's the headgasket then.
When our hatch engine was going out it was a matter of money which route would have been better to go with. If the engine swap is cheaper, then go with it, If repairing the current engine, with undiagnosed issues is cheaper, then do that.
Your choice is made infinitely easier if you are or are not going to do any of the work yourself.
Old Feb 7, 2012 | 06:41 AM
Civic2Fast's Avatar
I say as long as everything else seems to be fine, just replace the head gasket.
kp's Avatar
kp
Forget the head gasket, if you have any doubt of the condition of the engine then there's no point in investing in it. Buy an identical engine from a lower mileage civic and drop it in. Swapping in a different engine will cost you MUCH more money than you will originally anticipate, trust me.
Old Feb 7, 2012 | 06:58 AM
nerospy's Avatar
I think it might be better to swap the motor out. I have no idea what other problems could arise and i would hate to throw money at an unreliable motor. I only want the car to be reliable, its for a 16 high school kid. Shouls i stay with the same type of motor or is there a better choice?
Old Feb 7, 2012 | 07:00 AM
The Grumpiest
Old Feb 7, 2012 | 07:06 AM
nerospy's Avatar
Yeah thanks i read that the first time. Is there a certain motor that is more reliable then others?
Old Feb 7, 2012 | 07:07 AM
kp's Avatar
kp
There are many "better" choices, but we're talking money here, correct? Call around and get prices on the EXACT SAME engine from the same 92-95 CX Civic, buy one and drop it in.
Old Feb 7, 2012 | 07:08 AM
The Grumpiest
It's a Honda! They are all reliable if maintained properly! Replace like for like if you don't want any hassles with the swap/install.
Old Feb 7, 2012 | 07:18 AM
nerospy's Avatar
Ok thanks alot guys I appreciate the help!
Smityro
19
Jun 10, 2013 01:33 AM
porkyv2
Sep 13, 2010 06:58 AM
umby
12
Jan 14, 2010 03:18 PM
SFrogue85
Sep 5, 2004 04:07 PM
rob_honda
May 12, 2004 05:18 PM
