oil drain back suggestion needed
so ive been doing a lot of looking around locally and on the net but i need this.
i need the suggested fittings to use on a moroso oil pan for oil drain back for my oil catch can. thanks!
that pan uses 1/2" npt. same as a turbo drain flange. popular way to do it is to run a female flange on the turbo, double male adapter to a twin female 1/2" line and double male on the pan.
Okay heres mine going from the turbo to the pan:
This is bolted to the bottom of the turbo with a bit of RTV to seal things up
Goes to this
To a -10AN piece of braided line
To a 60 degree -10AN hose end
Which is fitted to a -10AN welded in fitting to the pan
The braided line is sealed to the brass fitting with a regular worm gear hose clamp.
Goes to this
reignofchaos
Jul 31, 2003 07:48 PM
