What's a good diagnostic tool for a 92 Civic?
Old Feb 6, 2012 | 03:26 PM
Jettplane's Avatar
Post What's a good diagnostic tool for a 92 Civic?
Old Feb 6, 2012 | 03:30 PM
hannslebo's Avatar
Default Re: What's a good diagnostic tool for a 92 Civic?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
This ^^^
And get yourself a multi-meter
You can also look into - compression tester / Leak down tester
Old Feb 6, 2012 | 03:35 PM
Former User's Avatar
A short piece of wire or paper clip.
Click the CEL link in my signature.
Old Feb 6, 2012 | 03:41 PM
Jettplane's Avatar
Originally Posted by hannslebo
https://honda-tech.com/forums/showthread.php?t=1901557
This ^^^
Is there an actual device that is sold that reads whats wrong with the car instead of counting and deciphering codes? That would be so much easier.
Old Feb 6, 2012 | 03:43 PM
There's no tool available that will do that, though you can spend thousands on an expensive scan tool.
Old Feb 6, 2012 | 03:57 PM
Jettplane's Avatar
I have an on board diagnostic tool which didnt cost that much but it has 16 pins. The Civic has 2 pins I believe?
Old Feb 6, 2012 | 04:00 PM
94EG8's Avatar
Seagull Management
I don't even think there was a proper scan tool, even if you did have unlimited funds. I don't even recall seeing anything for OBD1 when I worked for Honda (their own OBD2 scan tools are something else though)
I should add that having a real scanner is nice, they will do a lot more than just give you codes, you can check freeze frame data, check things like O2 sensor response times and such that you just can't do with a paperclip.
Old Feb 6, 2012 | 04:10 PM
CivicBlacksheep's Avatar
10 Year Member
A vaccum guage, compression tester, leak down tester, fuel pressure guage, vaccum pump, mulitmeter, smoke machine, BFH
Old Feb 6, 2012 | 04:20 PM
hannslebo's Avatar
As stated above...don't think their is anything like that. It's not hard at all to pull/count the blinks.
You know how to do that and have a multi-meter...it will do wonders!
Old Feb 6, 2012 | 04:41 PM
angrysmileyface's Avatar
The 16-pin tool is for obd2 cars and select 94/95 gm cars (they were early adopters of the connector but not the standard (those cars still spoke ALDL I believe)) Not sure if there is even any Snapon Brick support for early hondas, though supposedly there is a honda adapter but I dont guarentee that info. And if counting isnt your strong point, beer buys many friends who will count for you.
jDMJeRk
Northwest (Sales)
Dec 14, 2008 10:42 AM
itsm3paul
Oct 7, 2005 07:11 PM
