D or B tranny?
Old Feb 6, 2012 | 12:44 PM
droar's Avatar
Default D or B tranny?
im swapping an H23a1 into my sol and im going to get an adapter for a d or b series tranny to go on the motor. my question is, should i use a B series tranny or a D series tranny? i have a D series tranny already thats why i would like to use that but i need somthing that will be reasonable on the track
Old Feb 6, 2012 | 12:46 PM
Dc4LsTeG's Avatar
EK9
Default Re: D or B tranny?
B
Old Feb 6, 2012 | 12:48 PM
droar's Avatar
iight which B tranny do you suggest
Old Feb 12, 2012 | 06:14 PM
93 hatchguy's Avatar
i have never seen such and adapter, any pics? It would also depend on what you expect/use the car for. If your looking for quick stop light to stoplight, your want shorter gears, if your a top end junkie might condside s80 with LS gearing. My opinion though. I see alot of the "what should i use " questions and its really just a matter of preference.
Old Feb 12, 2012 | 06:26 PM
94EG8's Avatar
Seagull Management
H/F to D adapters exist, but they're really uncommon. They were never really designed for H-series engines either, they were designed to mate cheap F-series accord engines to even cheaper D-series transmissions and do away with custom mounts (except the driver's side mount) and custom axles and having to buy a shifter box and cables. It just happen's the the H-series shares the same bell housing bolt pattern. I think Bense was the first guy or one of the first guys to come up with this idea.
Old Feb 12, 2012 | 07:22 PM
Townson's Avatar
i'm a fan of damn near everything d series if you cant tell by my signature. but i would go with a b series trans. a d transmission wouldn't hold up vey well over time paired with that engine. just my thoughts.
Old Feb 13, 2012 | 06:00 PM
Kohen's Avatar
GSR
Old Feb 13, 2012 | 07:10 PM
ktsciv93's Avatar
what are you going to be using it for? auto x? circuit? drag?
Old Feb 14, 2012 | 06:52 AM
Red_Army's Avatar
b16a/b18c5 tranny. if you get the b16a though id switch to a bigger FD and LS 5th.
94DCTeg
Aug 8, 2011 12:20 PM
jdmEF8racer
Mar 14, 2006 06:21 PM
dustrag
Jan 27, 2004 12:11 PM
