after market seats
You can use the stock brackets. Just take em off the stock seat and drill a new hole(s) if needed so they bolt onto the new seat then they should just slide on.
Simple craftsmanship
I know on the crx that the stock rails and seat are not flat. It has a couple corners that are almost 1/2" to 1" off in height so you need spacers to use them properly. You can also redrill the rails within an inch or so, but if the width is off you need additional brackets or to drill the seat. I have the passenger sparco seat on stock rails and there is not much headroom. Better to buy aftermarket rails that you can attach to the floor, especially if you are tall.
buell22
Jan 26, 2008 12:38 PM
EgSalad
Sep 13, 2006 10:20 AM
Steezn4NOReason
Jan 8, 2005 02:03 PM
