Honda S2000 Honda S2000
Need Help: Rear Turn Signal
Old Feb 5, 2012 | 04:22 PM
typer_696's Avatar
Default Need Help: Rear Turn Signal
I recently purchased a 2000 AP1 w/ an oem hardtop. I can't find the correct rear turn signal bulbs. Parts inventory catalog and every where I look says 1156. The prongs on a 1156 go straight across.
When I pulled out the rear turn signal bulbs the prongs are in a angle, forming a V. So the 1156 don't fit. Does anyone know the correct bulb for this. Thank you for your help.
Old Feb 5, 2012 | 05:16 PM
Boots's Avatar
Default Re: Need Help: Rear Turn Signal
the bulb should have the part number on it
Old Feb 5, 2012 | 05:51 PM
typer_696's Avatar
I wished it did.
KOITO12v 21w PY21W E4 2DS JAPAN 9-7-C is what is written on the bulb.
Old Feb 5, 2012 | 06:36 PM
Vanishing Point's Avatar
This should help.
S2000 (AP1):
Lowbeam: D2S HID
Highbeam: H1 (55W)
Front turn signal: 7440 (21w)
Rear turn signal: 7440 (21w)
Brake Lights: 7443 (21/5W)
Old Feb 6, 2012 | 05:18 AM
typer_696's Avatar
It's not a 7440. And its not a 1156.
Old Feb 6, 2012 | 05:26 AM
Boots's Avatar
then its not the right bulb that should be in there....or somebody ****** rigged the sockets
Old Feb 6, 2012 | 06:13 AM
Typer,
Try this site, use either those displayed for comparison purposes or try the visual bulb comparison chart. If all else fails take the bulb to any auto supply and see if they can cross reference the bulb.
http://autolumination.com/1156_1157.htm
Old Feb 6, 2012 | 08:29 AM
dagle's Avatar
Lol if its not the factory one just yank off the socket and solder/crimp a new one on
Old Feb 6, 2012 | 10:48 AM
typer_696's Avatar
Thanks for the help. It's the 7507. The taillamps are oem and the harness is untouched. I guess they changed the sockets for whatever reason. If I find an 1156 socket the connects to the oem harness ill replace it. It all works so I'm not going to cut and solder a good harness. Thanks for all your help. I'll pick up the new bulbs tonight.
patrickvertigo
11
Apr 30, 2015 02:31 PM
DarkStreetRacerX
Lighting
Sep 24, 2007 06:50 AM
Honda96Ex
13
Aug 23, 2007 06:48 PM
AllMotorITR
Jul 5, 2001 04:43 AM
