d16z6 dowel pins??
hey i recently had to due a head gasket change on my 94 civic and happen to lose the pins that line up the head gasket and head i think they are called dowel pins but i havent been able to find where to get some.. So if any one knows where i can get these plz let me know.. thank you for reading this
Do a google.search or majestic honda. The #1 mail order oem part dealer. Or you could try ebay or a local junk yard/pick n pull. Did you get it checked by a machine shop for a flat mating surface, or for warpage? Head gaskets dont usually go bad on their own, there are usually other factors such as overheating, boosting, reused head bolts, etc...
My local dealership doesn't carry jack for older Hondas, call ahead and compare their prices to Majestic Honda, print out an invoice and bring it with if you buy local, apparently most will price match other Honda dealerships.
94301-14200 14x20mm dowel pin. You need two, they're a whopping $.93, so just do what I do and buy a few extra when you make an order to have this stuff on hand. Dowel pins, shift linkage roll pins, axle nuts, 10 and 12mm bolts, hood prop clips are all cheap and nice to have spares. All are under or around $1 each.
fgraciano1980
Mar 17, 2006 12:36 PM
