HELPPP car wont start!!!!! :mad:
Old Feb 4, 2012 | 04:36 PM
ekkidd91's Avatar
Default HELPPP car wont start!!!!! :mad:
Hey, i'm new to the forum not sure if post is in correct section but here it goes.
Have a 93 cx hatch with a swap, d16y8. Got the car back in summer 2011. Tried installing system in the car but kept blowing ecu fuse. Gave up & disconnected system, rather have the car running then stupid music. Last week bought a new amp wiring kit with thicker wires connected everything, fine no problems. I deliver pizza part time & while at work car decided at the end of the night not to start. I had driven from monday till friday not a problem, but on my last delivery car made no attempt to start just a "click" sound. Have a 2 month old yellow top so I know dead battery can't be the problem. Boss tried jumping the car, nothing. Push start it & it turns on. Went to autozone to check battery, starter, & alternator. They said battery is good but was reading at high temperature, alternator was good but should consider replacing soon, & the starter was bad, as i assumed. Got a used one as a replacement this morning & installed it. NOTHING, same as previous starter. Checked fuses, they're ok. Don't know what the problem is. When key is in the ON position dash lights up fine, fuel pump primes. Need help don't want to go to a mechanic who charges me $100 to tighten a screw! Thank you in advance.
Old Feb 4, 2012 | 04:49 PM
hannslebo's Avatar
Default Re: HELPPP car wont start!!!!! :mad:
How do you know the used starter was good? Did you have it tested?
Old Feb 4, 2012 | 04:59 PM
redm3turbo's Avatar
Old Feb 4, 2012 | 05:00 PM
ekkidd91's Avatar
the used starter wasnt tested but has warrenty..how do i go about testing it?
Old Feb 4, 2012 | 05:15 PM
hannslebo's Avatar
Screw driver from negative to positive posts on starter...make sure you're holding onto the plastic, or jumper cables
Old Feb 4, 2012 | 06:30 PM
ekkidd91's Avatar
Ok got it..will post results tomorrow
Old Feb 4, 2012 | 07:11 PM
Tk42's Avatar
Check grounds?
Old Feb 4, 2012 | 07:58 PM
Nemasis2009's Avatar
Did you have the distributor checked?
Old Feb 5, 2012 | 09:16 AM
ekkidd91's Avatar
Ok so i bench tested the starter & it's good. It spins & pops out. The distributor couldnt be the problem could it bc the car isnt cranking. Checking wires from battery to starter next
Old Feb 5, 2012 | 09:20 AM
grumblemarc's Avatar
The Grumpiest
Spark. Fuel. Air. That's all you need for an engine to run. Which one are you not getting?
Old Feb 5, 2012 | 10:08 AM
SolScifen's Avatar
make sure every things hooked up and getting power. if you can push start it theres a problem with the starter, either bad or not getting power.
Old Feb 5, 2012 | 11:11 AM
ekkidd91's Avatar
Yeah thats what im saying it must be the starter but it powers when i jumped it to the battery. I just measure the voltage on the starter when connected in the car & it wasnt reading anything. I sanded down & cleaned the connection on the starter on the cable from the starter to the battery & its now reading 12.6v but car still wont start or crank!
Old Feb 6, 2012 | 05:35 AM
ekkidd91's Avatar
anyone know whats going on?? have to work at 11 today dont want to have to be push starting it everywhere
Old Feb 6, 2012 | 06:12 AM
pityocamptes's Avatar
How about your ignition switch?
Old Feb 6, 2012 | 09:02 AM
SolScifen's Avatar
when you go to start the car do all your dash lights go off?
Old Feb 6, 2012 | 09:35 AM
motegicivic's Avatar
Check for spark.
When you turn the key to number 2 do you hear the fuel pump prime, a click in the right side of the dash.
Old Feb 6, 2012 | 11:53 AM
ekkidd91's Avatar
ok to answer all the questions
1. when i go to start the car the dash lights stay on constantly no dimming or anything.
2. when key is in number 2 (ON II) main relay under dash clicks & fuel pump primes
3. my friend was explaining to me yesterday about a clutch switch & ignition switch dont know info on that he's supposed to come later today to take a look
Old Feb 7, 2012 | 04:09 PM
ekkidd91's Avatar
Ok so my boy took a look at he found the problem. Theres a yellow connection on top of the clutch pedal that broke off. He ghetto rigged it by putting speaker wire into the two connections & now the car starts but i dont need to step on the clutch. I've searched and its coming up as clutch interlock switch. Can anyone confirm this 100%? Will be going to honda tomorrow to buy it just want to make sure im getting the right part.
Old Feb 8, 2012 | 01:18 AM
ekkidd91's Avatar
anyone^??
Old Feb 8, 2012 | 01:25 AM
vartok's Avatar
that sounds right, but id just tell the guy at the parts counter what the issue is and he should be able to 100% it.
dungsta
Acura TSX
14
Jul 11, 2013 11:37 PM
EGHondalover88
31
Jan 18, 2010 03:26 PM
lawlss
15
Sep 14, 2009 10:23 PM
silverdragon277
Aug 19, 2006 10:42 AM
SOKDO
Jun 2, 2005 10:33 AM
