ls vtec and block guard question
Old Feb 4, 2012 | 02:52 PM
2000EKCoupe's Avatar
10 Year Member
Default ls vtec and block guard question
hey HT. Im currently building an ls/vtec b18b1 bottom end with gsr top end. Nothing crazy is being done, just p30 pistons and ITR valvetrain. Ive been researching and ive been getting mixed answers on whether or not to use a block guard for this build, My machinist recommends it but i dont think its nec. whats the pros and cons?? this will be my DD for a while too.
Old Feb 4, 2012 | 03:30 PM
doood's Avatar
been there done that
Default Re: ls vtec and block guard question
spend the money on arp rod bolts, headstuds, and balancing the bottom end. a block guard will do nothing for you.
Old Feb 4, 2012 | 03:48 PM
10 Year Member
Thanks. I'm definantly buying all those regardless. But I can never get a clear answer on this for some reason.
Old Feb 4, 2012 | 04:01 PM
10 Year Member
ive read a lot of good things and a lot of bad things about them.
Old Feb 4, 2012 | 04:15 PM
doood's Avatar
what makes you think you need one?
Old Feb 4, 2012 | 04:24 PM
10 Year Member
i thought it would be good insurance, but after researching and asking around i figured theres no need for one for my power goals. the machinist im bringing my block too just recommended it so i just wanted to look into it again
Old Feb 4, 2012 | 04:35 PM
DirtyDA9's Avatar
Block guards do more harm than good. They put stress on the cylinder walls.
This is the last time I will explain this, as I am tired of saying it lol
The casting on the outside of the cylinder walls are different in every engine, different high and low spots here and there, while the block guard is machined flat, and will put stress on the high spots, obviously causing stress on the cylinder.
Old Feb 4, 2012 | 04:57 PM
10 Year Member
thats what ive read also, thanks
Old Feb 4, 2012 | 07:20 PM
b20_EM1's Avatar
False, Lol the web is full of false information. Block guard will benefit you. I have a Golden Eagle sleeved block with a block guard from Golden Eagle!, why would they do that cause they know wtf they are doing! Check my build thread.
Old Feb 4, 2012 | 07:28 PM
10 Year Member
Lol that's what I'm thinking. I'll check it out def
Old Feb 4, 2012 | 07:30 PM
10 Year Member
That's what I said ! Lol post it up and I'll def check it out dude
Old Feb 4, 2012 | 07:50 PM
doood's Avatar
that "block guard" on ge sleeves is actually incorporated into the sleeve. not really a block guard in the traditional sense at all.
Old Feb 4, 2012 | 07:57 PM
DirtyDA9's Avatar
Think about what you are saying, GE SLEEVES!... GE sleeves arent casted, therefore they are perfectly machined all the way around unlike factory cast cylinders. Your logic is poo.
Old Feb 5, 2012 | 04:27 AM
10 Year Member
lol got a point
Old Feb 6, 2012 | 03:30 PM
10 Year Member
what HP should i start looking into block guards? my goals are hopefully around 190 HP.
Old Feb 6, 2012 | 03:36 PM
doood's Avatar
when you start making more power than the stock sleeves can handle. so if you're sticking to NA, never. unless you crack a sleeve somehow, then resleeve it.
Old Feb 6, 2012 | 04:35 PM
10 Year Member
Lol thanks. It's a pretty straight forward build
a1320addict
May 9, 2005 12:43 AM
turbociv
Mar 28, 2005 02:46 PM
rusteds2k
Dec 2, 2003 01:44 PM
spyder
Nov 11, 2001 03:25 PM
