Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: how replace internal seal distributor internal oil leak
Step by step instructions for do-it-yourself repairs.
Oil leak issues on a 2000 Accord DX, distributor?
I had changed the oil at 108k and recently found that the oil was nearly out at 114k. First off, I shouldve checked and changed the oil before now I guess every 3-4k, but I had noticed that the distributor looks like its got a leak at the base. Nothing has shown up on the driveway to indicate a big leak, but I think its probably time to replace the distributor since the last tune up was done at the dealer at 102k.
Questions:
How often should a tune up be done? 10-15k?
How difficult is a tune up on the 2000 Accord DX? Is it just replacing the distributor, plug wires, and plugs?
Where should I check for potential oil leaks?
Questions:
Spark plugs (NGK or Denso) should be changed every 30,000 miles. Personally, I would change the wires (NGK), distributor cap (HONDA),rotor button(HONDA), and plugs (NGK) all at once especially. Next 30,000 I would inspect everything but the plugs and just change the plugs.
The leak you are experiencing is very slow and probably dries up before reaching the ground.
Potential places for oil leak: Camshaft seal, balance seal, crank seal all on the timing belt side. Oil pressure sensor, oil pan, and oil filter on back of engine. Valve cover gasket on top of engine. Distributor can be leaking from two places. First and easiest remove the distributor cap. If no oil is found inside, the internal seal is not leaking. If leaking outside, it's the external seal, which requires removal of the distributor (3 bolts). Hope that helps
Took some pics of what its looking like. I see oil mainly on the distributor and the oil pan. I assume this is what a leaky oil pan gasket looks like?
Looks like the oring around the dizzy. The seal inside the dizzy, if bad would show oil
inside the dizzy. The picture you show of the inside of the dizzy looks dry.
H
H
So get and install this part?
http://www.oreillyauto.com/site/c/de...5095&ppt=C0334
Any tips on removing the dizzy and replacing this part?
http://www.hondaautomotiveparts.com/...8401_e0510.png
Basically you remove the distributor, mark it first to keep original timing.
On the shaft of the distributor there is an o ring, you take it off and replace it, like a $2 part from honda, I would get it from honda to make sure you have the right part and it seals right.
Since I have never removed/replaced a distributor is marking it just noting once I pull it where the rotor on the distributor is pointed?
I saw this clip on youtube and from what I can see he notes the timing marks that can be dialed.
http://www.youtube.com/watch?v=bVv_57uSrUQ
Ok, the accords are different than the civics, the civic you can scribe the top of the dizzy to the top of the bolt housing the accord you can not.
Do the similar steps above to remove it, but pull it out slowly and make sure it does not spin when taking it out, there are ears that fit one way. When you replace the o ring be careful not to spin it or remember how the ears are positioned and put it back should slide right in.
Finally getting around to replacing the distributor oring, plug wires, cap and rotor. I removed the distributor and saw that there is some oil on the inside of the distributor. I had a few questions at this point
Some pics
Here is a close up of where the leak seems to be from the gasket.
its splashed a bit of oil inside
How do I get access to the oring from here?
- Is the gasket/seal that fits around the perimeter of the distributor that makes contact with the cap the culprit here?
- Or is it the oring?
- How do I replace the oring? Do I have to disassemble further to get proper access to the oring, if so how?
- Should I be concerned about the oil that has splashed inside of the base of the distributor? Just wipe it down?
Some pics
the o-ring there looks like it might be kinda worn out, but that would cause external leakage. the internal seal is not easily replaceable, easier to just find a junkyard distributor housing and use all your known-good parts in it. with internal distributor leakage your cam position sensor will eventually die.
Some pics
Some pics
I speak from experience
https://honda-tech.com/zerothread/2214402
http://www.partstrain.com/store/deta...3-1640599.html
btw this seal normally won't fit aftermarket distributor housings as I've found out myself, however some aftermarket distributor internal seals have a bad spring on the internal seal that you can take your OEM spring and put it on.
I have a 99 accord ex, same exact issue. I bought a new distributor housing. Since you have over 100,000 miles you will be getting more than just a new seal. Normally seals go out due to age/heat/bearing slop.
Majestic Honda has good prices online, you need item # 4 (housing)
http://www.hondaautomotiveparts.com/...+%28HITACHI%29
At this point after looking at the post on how to replace the seal, I am pretty sure I will mess something up. I dont like spending more than I should but, considering the miles on this dizzy and since this is my wifes car and I figure spend the $170 on the housing.
Once I get the part, how precise does the rotor/shaft position have to be?
I took this pic just as I removed the dizzy without moving the shaft.
Will lining it up approximately as pictured work fine?
The distributor can only go in one way. Do you remember which direction the rotor cap was pointing?
Transfer the internals to the new housing (carefully) then install it. Put some oil on the seal before stabbing it, making sure the rotor cap is pointed in the correct direction. Once it is installed you should check your timing, but I am pretty sure that once it is started the ECU will adjust everything.
If you look at the picture, the distributor cannot be installed 180 degrees out as the prongs are offset from center.
I havent checked timing yet, but it isn't noticeably off.
I'll learn how to do that tomorrow. Ive got a timing gun and a Haynes book to hopefully get it done right.
Running great,
Thanks for all the help here!
One thing that was embarrassing is that this Accord isnt a DX, its an SE. Good thing I figured this out sonner than later so I got the right parts.
CRXDaddy78155
11
Feb 19, 2007 01:03 PM
