d16z6 build
Old Feb 2, 2012 | 06:24 PM
xero_xero's Avatar
Default d16z6 build
Looking at building a d16z6 bottom end
possibilities list
d17 crank
p29 piston
blox cam
if anyone can chime in and post up dyno sheets of similar setups. looking for N/a all motor. relly looking to pick up some midrange torque.
Old Feb 14, 2012 | 04:22 PM
CivicSi95's Avatar
Default Re: d16z6 build
im 99% sure you cannot use d16 pistons with the d17 crank and rods. you need to source some civic ngx pistons for highest compression or buy custom pistons
Old Feb 14, 2012 | 04:59 PM
m_shake's Avatar
D16 piston will stick way the **** out, need d17 pistons, preferably gx ones as they net 12ish:1 compression, also don't plan on revving too high d16 rod/stroke ratio is shitty and a d17 is even worse and their rod bolts are dinky... There's a hondatuning article about the super d, cliffs:it blew up
Old Feb 14, 2012 | 06:51 PM
xero_xero's Avatar
lolz. i havea set of cp pistons now, they are about 11.5 to 1 but they came out to be just over 11 slightly.
believe it or not, the rods are the same legnth in the d16/d17 , just a difference of pistons and crank.
i believe ill just d\save my pennies for the swap i want.
Old Feb 14, 2012 | 07:06 PM
m_shake's Avatar
Think d17's are narrower on the big end of the rod, but yes same length as d16/d15b vtec. Wise choice in saving for swap. I've always wanted to do a all motor d series but in the end it just don't make sense $$$ wise
Old Feb 14, 2012 | 07:47 PM
xero_xero's Avatar
im still looking at cam and upgrade options just for minor bolt ons. already have teh limited slip. just looking for more torque, power, and powerrrrrrr.
Old Mar 21, 2012 | 03:26 AM
94EG8's Avatar
Seagull Management
I thought about that combo before. It nets over 15:1 compression. Unless you want to run it on diesel you'll need to go with lower compression pistons.
Old Mar 21, 2012 | 04:40 AM
xero_xero's Avatar
it takes custom pistons to clear with a decent compression. zc, z6, y8, and any others i could get my hands on were too tall. they would have to be milled.
Old Mar 21, 2012 | 05:54 AM
94EG8's Avatar
Seagull Management
P08s from a D15B Vtec look like the sweet spot for pump gas. 9.61 compression ratio. Hard to find used though. P07 VX pistons look like they would yeild a low 8.13:1 compression ratio, might be nice for boost.
Nice D-series compression calculator if you haven't seen it before -> http://www.zealautowerks.com/dseries.html
Old Mar 22, 2012 | 11:55 PM
oldcivicjoe's Avatar
sportsman racing 10.3:1 pistons, -2.5 cc invert dome, with the crower stage 2 cam and aem cam gear set to 3 deg advance, with the bbk 62mm tb and a slightly larger set of injetors, then set the vtec valve to open at 3800 rpms and theres your midrange d16z6
DelSolDon
Apr 2, 2011 11:29 AM
dacuslil
24
Aug 6, 2008 05:06 PM
turbohatch101
Jan 5, 2008 01:42 PM
turbo420
Feb 29, 2004 09:40 PM
97 BB6
Sep 9, 2003 10:49 PM
