2009 RDX OEM Remote does not work properly
Hi,
I have a 2009 RDX with the OEM Remote starter installed in it. Yesterday, I found out that the Remote is not working anymore. Here's what happen...
If I try to lock / unlock the door, the remote controller will make a "beep" confirming the command has been send to the unit in the car but nothing happen and the door are still unlock or locked depending the situation.
If I try to start the car, the remote will make a "beep" confirming the command and the car will try to start. The starter is turning etc... but the car doesn't start. If I go in the car and start the engine manually, it works perfectly.
Does anyone have an idea what may cause this issue?
Thank you in advance.
myaccord2004
Feb 9, 2018 02:12 PM
domrw
Honda Civic (2001 - 2005)
Sep 9, 2017 12:54 AM
