Gunk Oil Cleaner ok to use?
Old Oct 9, 2002 | 09:01 AM
ragejed's Avatar
Default Gunk Oil Cleaner ok to use?
I picked up a Botle of Gunk Oil cleaner...You use it before you change your oil..Dump it in your engine, run your engine for 5 mins, then drain your oil, and charge your oil and filter. Anyone use this stuff? Is it safe to use?
Old Oct 9, 2002 | 09:39 AM
ragejed's Avatar
Default Re: Gunk Oil Cleaner ok to use? (ragejed)
Anyone?? I wanna go change my oil...Dunno if i should use that stuff
Old Oct 9, 2002 | 09:42 AM
vtec.dc2's Avatar
i'd stay away from these products.. i think its better to change your oil more regularly.. than use engine cleaners...
Old Oct 9, 2002 | 09:43 AM
ragejed's Avatar
Default Re: Gunk Oil Cleaner ok to use? (vtec.dc2)
I bought the car used at 39k...As it was..The oil filter looked like it was changed at 15k..so I am assuming that they never did the 30k tuneup..I just did a 30k and 45k tune up...trying to get everything running right.
Old Oct 9, 2002 | 10:23 AM
ragejed's Avatar
Alright..I might as well use it...But..Should I put on a cheap oil filter, and put in cheap oil...drive it for like a hundred miles, then put my mobil1 oil and filter in? Just to make sure its cleaned out?
Keep in mind I am replacing my oil pan gasket as well.
Old Oct 9, 2002 | 10:26 AM
smdandb2's Avatar
YES, that is the way to do it!
I use the Gunk cleaner every oil change in my mazda... keeps my HLA tap down to a minimum! The guys over at probetalk use engine cleaners religously!
Old Oct 9, 2002 | 10:27 AM
ragejed's Avatar
Default Re: Gunk Oil Cleaner ok to use? (smdandb2)
What kind of cheap oil can I use for like 100 miles? Since I use Mobil 1 syn, must I use syn for these 100? or can i get some cheap ****? and drive easy?
Old Oct 9, 2002 | 10:28 AM
smdandb2's Avatar
I just used cheap **** and a cheap filter. Didnt even drive for 100 miles. Just went for a 20 minute cruise and drained the oil again!
Old Oct 9, 2002 | 10:29 AM
ragejed's Avatar
sounds good
gunna go pick up cheapest ****, lol
Old Oct 9, 2002 | 12:40 PM
fuguman's Avatar
New User
i used it last oil change
after i drained it i just put my regular oil in it and gonna keep driveing til next change
Old Oct 9, 2002 | 01:25 PM
Fuuma0083's Avatar
Default Re: Gunk Oil Cleaner ok to use? (fuguman)
Whenever you buy a used car its always good to replace all of the fluids in the car.
Old Oct 9, 2002 | 01:38 PM
ragejed's Avatar
Default Re: Gunk Oil Cleaner ok to use? (Fuuma0083)
Alright, i picked up napa Oil for 99cents, and a napa fiter for 2.50, hehe Just so i can clean the left over dirtyness out, then in with the new mobil one
Old Oct 9, 2002 | 03:36 PM
ragejed's Avatar
Lol. couldnt get the damn old filter off....Had to put 5 holes in it..no wrench, all stores wereclosed. damn sun, hides it self too damn early. So ya, I have napa oil and filter in my car till tomorrow morn. I am going to do my oil pain gasket and **** then
Old Oct 10, 2002 | 06:54 AM
ragejed's Avatar
What do you use to clean the oil pan and block when installing a new gasket on it? Brake parts cleaner? I just want to say its annoying to change this gasket Had to take off the A-pipe, the shield on the tranny (can see the flywheel now) and some bolts that hold the brakets from the tranny to block.
My engine is nice and clean tho
Relized that when I painted my valve cover that that I put the ground to my valve cover...not to the stud, lol.
Moo-Moo
19
Aug 12, 2010 09:10 PM
billy hoang
Mar 11, 2010 10:59 PM
tekniq
34
Jun 11, 2008 09:40 PM
o0oz
Feb 20, 2007 04:54 PM
JOMO
Feb 10, 2003 08:33 AM
