Firewall connector Tucked harness
Old Feb 1, 2012 | 04:21 PM
ZCHondaCRX91's Avatar
Default Firewall connector Tucked harness
I'm doing a tucked harness and was going to just do it straight from the engine to the ECU/gauges, that way has worked before. But saw this connector on ebay and seems to be pretty decent. Talked to the guys selling it and they said they are metal (not plastic), and the pins are removeable (which seems really handy). This would make it easier to have it on the firewall and just disconnect if I need to. I don't wanna spend all the money on a mil-spec connector, but $20 seems to be pretty good. Any of you guys use these before?
http://www.ebay.com/itm/300562738118...84.m1423.l2649
Also, can you solder the wires to the pins or do you have to have the special crimper to connect them?
I found these also, Soviet connectors that look stronger (pins aren't removeable, that's the only difference).
http://cgi.ebay.com/ws/eBayISAPI.dll...m=250986584427
Old Feb 1, 2012 | 06:28 PM
98civdx's Avatar
Master Detailer
Default Re: Firewall connector Tucked harness
A $20 milspec plug!? Pass.
It looks like it is plastic.
Old Feb 1, 2012 | 06:56 PM
grumblemarc's Avatar
The Grumpiest
The green one looks like hard plastic. The Soviet one looks like metal. Both are cheap. Don't even know why you stopped in here to start a thread since either is an inexpensive alternative.
Get one and see how the wiring goes after.
Old Feb 2, 2012 | 07:36 AM
Yeah I guess I can just get one and see, but thought someone must of used them before. The only other ones I see are well over $250 or don't have enough pins. Do you guys know of some cheap, but proven plugs?
Old Feb 2, 2012 | 07:56 AM
The Grumpiest
According to this
http://www.j32a.com/showthread.php?t=949
all you need is solder and wire.
Old Feb 2, 2012 | 08:01 AM
Dc4LsTeG's Avatar
EK9
^ its solder to the wires that are already crimped. If he gets one off eBay that doesn't have wires in it like the ones posted above you need the crimper.
Old Feb 3, 2012 | 09:05 AM
Yeah, the only ones I see cost over $250 and don't look that complicated, then just have a complete circle crimp instead of making a pancake out of it. Know of any cheaper ones?
Old Feb 3, 2012 | 09:41 AM
98civdx's Avatar
Master Detailer
Don't forget the crimper to do this is $300+
Old Feb 3, 2012 | 09:56 AM
That is what I was asking about.
Old Feb 3, 2012 | 10:09 AM
98civdx's Avatar
Master Detailer
The cheapest I have found is $369
Old Feb 3, 2012 | 09:35 PM
uberEFtuner's Avatar
Do you want a connector on the firewall? Or do you just want the ability to disconnect everything in one shot?
Old Feb 4, 2012 | 08:11 AM
Well I was going to just run it without any quick disconnect connector but if it's cheap enough I might just do it. Is there any 40+ pin connectors that aren't firewall mounted ones, maybe just a plain connector?
Old Feb 4, 2012 | 09:59 AM
BB6-213's Avatar
I wonder what all is needed for the soviet connectors to make it work?
Old Feb 4, 2012 | 10:50 AM
I was thinking of getting a connector from another vehicle. And also I would mount it inside the car. So that it does not have issues with water and road grime.
Old Feb 4, 2012 | 09:20 PM
Seems like just the special crimper tool. I will order one and see.
S2k@9K
17
Aug 20, 2018 04:14 PM
$MIKE$
Jun 12, 2014 02:04 PM
soon2befast
Jul 2, 2010 03:09 PM
asigler
Jul 22, 2009 10:59 AM
Jamarquis
Sep 26, 2008 08:21 AM
