Vtec wiring?
Old Feb 1, 2012 | 11:42 AM
Barry116's Avatar
Default Vtec wiring?
I am new to honda and acura so im still learning, but i bought a 1989 honda civic HB with a b18c and the vtec was not hooked up. it has the p72 ecu i was told. i have the 3 wires that go into the vtec solenoid hooked up and the o2 sensor, the vtec is either really weak so i cant tell or its just not engaging, advice/ info anyone?
Old Feb 1, 2012 | 11:43 AM
Dc4LsTeG's Avatar
EK9
Default Re: Vtec wiring?
Check what ecu you have first
Old Feb 1, 2012 | 11:47 AM
Barry116's Avatar
It is a p72
Old Feb 1, 2012 | 11:50 AM
Dc4LsTeG's Avatar
EK9
Are you positive? In your post it says you were told. Never believe the person you bought a car from
Old Feb 1, 2012 | 11:52 AM
Barry116's Avatar
i just checked, i looked at your pics and saw where it tells you so i looked
Old Feb 1, 2012 | 11:59 AM
Dc4LsTeG's Avatar
EK9
Here hope this helps
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
crx_si-r's Avatar
Also maure sure it wired up properly. Your ecu jumper may not be wired up right
Old Feb 1, 2012 | 12:04 PM
Barry116's Avatar
ecu jumper?
Old Feb 1, 2012 | 12:07 PM
Dc4LsTeG's Avatar
EK9
You'll have a jumper harness for that ecu. What obd is the ecu obd1?
Old Feb 1, 2012 | 12:14 PM
Barry116's Avatar
yes
Old Feb 1, 2012 | 12:16 PM
Dc4LsTeG's Avatar
EK9
So you have a jumper harness. Check the wiring on that
Old Feb 1, 2012 | 12:38 PM
Barry116's Avatar
What is the jumper harness? this is the first vehicle ive owned like this, my last vehicle was an 86 chevy pickup
Old Feb 1, 2012 | 12:40 PM
Dc4LsTeG's Avatar
EK9
It's the harness plugged into your ecu so you can use an obd1 ecu
Old Feb 1, 2012 | 01:46 PM
4drEF's Avatar
Keyboard Humorist
How do you know vtec isn't working?
Is your CEL lit up?
It shouldn't slam you into your seat as it's supposed to be a gradual changeover.
When you are driving and go over about 4500 RPM, do you hear your exhaust/intake change pitch?
Old Feb 1, 2012 | 01:56 PM
KINGVEM^^ED6's Avatar
Check oil
No oil no vtec
96_cvc_b16
13
Mar 21, 2009 08:37 PM
ek coupe
81
Feb 28, 2009 07:26 PM
F5sGsrHatch
Mar 22, 2007 08:06 AM
MM's94Civic
Jun 30, 2004 08:59 PM
khang77642
Aug 13, 2002 10:05 PM
