Radiator question! help!
Old Jan 31, 2012 | 11:46 AM
chrisalvar's Avatar
Icon2 Radiator question! help!
1994 Civic LX auto tranny
Ok, so i just replaced fan, radiator, hoses, and thermostat.
I go to work at 2am, it takes me 3 minutes tops to get there.
By the time i get to work my temp gauge is already at the
halfway point! Its cold as ice outside! Is that normal?
ALSO, today i got off at 12pm. Took me 4 minutes to get home.
Of course, temp was halfway again. I popped the hood and
noticed the top radiator hose was hot, but the bottom one was
cold. Is that normal as well?
I did burp out radiator twice and today before i started the car
i opened the cap and it was topped off so i dont think there's
any air in there.
Old Jan 31, 2012 | 11:47 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Radiator question! help!
Change the thermostat.
Old Jan 31, 2012 | 11:49 AM
chrisalvar's Avatar
I just did. Its brand new.
Old Jan 31, 2012 | 11:50 AM
Dc4LsTeG's Avatar
EK9
Are your fans coming on?
Old Jan 31, 2012 | 11:51 AM
The Grumpiest
Make sure the thermostat is actually working. Did the temp ever go past the halfway mark? Does the fan come on?
Old Jan 31, 2012 | 11:59 AM
chrisalvar's Avatar
Gauge does not go over halfway mark. Still havent seen radiator fan come on. When i turn on AC only one fan comes on, not the radiator one though.
Old Jan 31, 2012 | 12:01 PM
Dc4LsTeG's Avatar
EK9
Try jumping the fan or let your car idle and see of the fan comes on
Old Jan 31, 2012 | 12:03 PM
chrisalvar's Avatar
I did let the car idle for 10 minutes after burping it. Gauge at halfway point, fan did not come on. I also replaced the fan relay. And AFTER A WHILE lower hose did warm up. Could it be the fan switch or sensor?
Old Jan 31, 2012 | 12:15 PM
cvcrcr99's Avatar
You are fine. Lower hose should get warm after awhile. These motors do not produce much heat, so it will take a little while before everything is warmed up. If you are not overheating, then you are fine.
Edit - if you must test the fan, unplug the fan switch and stick a paperclip into the plug (harness side of course) with the keys out. Turn the car over so it has power and the fan(s) should come on. If not, the fan is dead, or there is a wiring problem. If they do come on, the switch may be dead. either that... or the colder weather is keeping the car below the fan switch's activation threshold.
Old Jan 31, 2012 | 12:19 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
lol @ "replace the thermostat". How does a failed Honda thermostat cause overheating?
OP, I'm sure you're fine as long as the car doesn't overheat after idling for a while. Check back in the summer time. Did you replace it with an aftermarket thermostat that maybe has a smaller opening or "hotter" spring?
Old Jan 31, 2012 | 12:22 PM
The Grumpiest
Where was it stated that it was overheating? Don't read more into it than was stated. I only suggested to check it. Definitely replace it if it is not working.
Old Jan 31, 2012 | 12:30 PM
cvcrcr99's Avatar
I have seen failed Honda Tstats stick closed and cause overheating. Of course this is after the owner already popped a head gasket overheating the **** out of the motor and never replaced the Tstat when rebuilding..... but I have seen it happen before lol
Old Jan 31, 2012 | 03:41 PM
HondaPartsHero's Avatar
Technical Hero
Bleed the coolant system if you didn't, you probably have an air pocket
SlowB16
Feb 22, 2013 05:59 PM
Freeclowns
11
Apr 14, 2012 04:36 PM
EGcivic_95
31
Jan 29, 2011 06:09 PM
spock_rocker
Jun 6, 2005 03:32 PM
xZeler8
Nov 26, 2004 10:47 PM
