96 gsr swap into 94 dx
Old Jan 30, 2012 | 01:08 PM
JimmiMorris's Avatar
Default 96 gsr swap into 94 dx
okay so ive bought a complete 1996 jdm gsr swap. The shock tower harnesses plug right in after i rerouted them underneth my intake manifold. my question is, since my car is obd1 and this engine is obd2 will i need to rewire my alt,dizzy and injectors.everything plugs in that i have and i have a p72 that also plugs in but the car wont start, how do i prove if the ecu i have is obd1 or obd2. or should i just buy the obd1 to obd2a conversion harness?
Old Jan 30, 2012 | 01:15 PM
Gsrsi's Avatar
Default Re: 96 gsr swap into 94 dx
Last number identifys obd
Old Jan 30, 2012 | 01:19 PM
37820-p72-942
804-200376
thats what is says on my ecu, so what number are you talking about?
Old Jan 30, 2012 | 01:28 PM
HondaPartsHero's Avatar
Technical Hero
I'm confused if the ECU plugs in then it is OBD1. The car isn't cranking or the car won't start? If it cranks but no start then check if you have spark and fuel.
Old Jan 30, 2012 | 01:39 PM
okay, so obd1 harness' will not plug into obd2 ecus? and yes the car cranks with no start
xxliljonxx1
14
Mar 21, 2012 07:57 AM
2drh22
Feb 26, 2009 06:09 AM
lVlemphizStylez
Feb 16, 2007 07:15 AM
civichbb18
Dec 15, 2004 03:28 PM
