All motor b20vtec not shifting in high rpms.
Old Jan 30, 2012 | 07:26 AM
BoostThisMS's Avatar
Default All motor b20vtec not shifting in high rpms.
I have an all motor b20vtec eg hatch with a built motor and it turns right around 10.5k rpms and it wont seem to go in gear around those rpms.
Any suggestions as to what i can do.
Has a GSR trans with obx lsd.
Old Jan 30, 2012 | 07:36 AM
guachi1209's Avatar
Default Re: All motor b20vtec not shifting in high rpms.
Dammmm you take your b20 all the way up too 10.5k
i really hope you have at least arp rod bolts
Old Jan 30, 2012 | 09:00 AM
its a 14.5:1 comp fully built b20vtec.
Old Jan 30, 2012 | 09:04 AM
blackeg's Avatar
Check the pressure plate as well as your fluid and slave cylinder
Old Jan 30, 2012 | 09:20 AM
b20vtech's Avatar
what brand clutch kit you have?
Old Jan 30, 2012 | 12:46 PM
carolina clutch stage 6 clutch, with exedy stage 2 pressure plate
Old Jan 31, 2012 | 06:53 AM
b20_EM1's Avatar
I have the same problem built b20 vtec, mine won't go into gear at 9400 rpms but when I power shift it at 8900 it goes in perfect. Those last 500 rpms make a difference.
Old Jan 31, 2012 | 10:53 AM
canthangwitdis's Avatar
take the gearbox apart. gears, synchros, and sleeves gotta be top notch to shift at those rpms!!!
madcrx69
Transmission & Drivetrain
May 19, 2014 01:27 PM
mouab18c1
45
Aug 29, 2012 06:23 AM
TurboCivicR93
12
May 5, 2011 12:56 AM
092eg6
11
Apr 22, 2010 05:58 AM
rig9896
Sep 22, 2003 11:34 AM
