Always Blowing Air DC5
Old Jan 29, 2012 | 06:47 PM
UASK20's Avatar
Default Always Blowing Air DC5
I have recently ran into some problems with my AC/Heat unit and have noticed that it is constantly blowing air/heat at full blast. When the control is set to off it still blows this air and when i turn the **** to low or full blast it is still the same flow of air and i can hear the fan kicking on. I do notice an idle change when i move the switch from the off position to anywhere from low to high and it does change from heat to ac when i switch from the highest temp setting to the lowest temp setting. The defroster works as it normally does when it is set to work so i am wondering if the blower motor transistor or bad or what is the main source of this problem. All fuses check out to be in working condition.
Old Jan 30, 2012 | 05:32 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: Always Blowing Air DC5
sounds like your resistor has gone bad. I would definitely replace that to start with
Old Jan 30, 2012 | 11:38 AM
UASK20's Avatar
alright thanks Spaz didnt get too much help on ClubRSX but thank you.
Old Jan 30, 2012 | 07:36 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
No problem
I didn't see your thread on CRSX but I've been in the hospital for the last two days. lol
SGS97EX
Aug 17, 2013 01:11 AM
leemcdaniel
Oct 17, 2010 06:29 AM
Milano4
Jun 9, 2004 12:15 PM
matix
Sep 20, 2003 09:36 AM
AGPSuperstar
Apr 4, 2003 10:36 AM
