93 Civic Si - How do I wire a honda bullet pro distributer?
Old Jan 29, 2012 | 03:25 AM
kyleeuuu's Avatar
Default 93 Civic Si - How do I wire a honda bullet pro distributer?
i have a jdm obd1 gsr motor in my 93 si think i used the si harness and the plug to the distributer on the harness is 2 peices and on the bullet pro distibuter has a bigger plug that is a 9 pin instead of a 7pin connector anyone know how to fix this so that it works ill post pictures of it when i get a chance
Old Jan 29, 2012 | 05:43 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 93 Civic Si - How do I wire a honda bullet pro distributer?
You mean the Pro-Billet distributor from MSD?
http://www.msdignition.com/instructiondownload.aspx
Old Jan 29, 2012 | 11:21 AM
kyleeuuu's Avatar
yeah thas the one im trying to put on my car
Old Jan 29, 2012 | 11:23 AM
The Grumpiest
What OBD distributor is it?
Old Jan 29, 2012 | 11:43 AM
94EG8's Avatar
Seagull Management
It sounds like you're trying to use an OBD2 distributor with an OBD1 wiring harness, rywire makes adapter harnesses or you could get an OBD1 distributor. Also unless you're making 500+ HP I'd forget the MSD setup, I've seen more guys have trouble with them than I can count.
Old Jan 29, 2012 | 12:36 PM
The Grumpiest
http://www.rywire.com/catalog/distri...ters-c-11.html
Old Jan 29, 2012 | 02:32 PM
kyleeuuu's Avatar
i already have the full set up and its set up in my hondata to im not making 500hp but since i have the 6al with 2 step, blaster coil , coil driver and the distributer i might as well buy the adapter so it works.
Old Jan 29, 2012 | 02:38 PM
The Grumpiest
Might want to make sure it will fit BEFORE you buy it. Unless you have money to burn.
audiobyalbert
Jun 19, 2010 06:01 AM
bb6_00
Jan 26, 2009 09:45 PM
terribl3jon
Dec 3, 2005 02:09 PM
Eg6LazyPt
May 15, 2003 08:52 PM
boomslang
Jul 25, 2002 12:21 AM
