Mount points for different engines?
Old Oct 9, 2002 | 04:47 AM
Pele's Avatar
Default Mount points for different engines?
Do all the engines in a series have the same mount points? What about Tranny bell housing bolt patterns?
Old Oct 9, 2002 | 10:06 AM
Louie B.'s Avatar
Default Re: Mount points for different engines? (Pele)
yes
Old Oct 9, 2002 | 10:18 AM
spettinger's Avatar
Default Re: Mount points for different engines? (thumpu77)
yes, provided that you are talking cable to cable, not cable to hydro swaps.
Old Oct 9, 2002 | 11:53 AM
rpr's Avatar
rpr
Define 'series'? And you are talking about engine mounts as well as trannies? A D16A1 has different mounts from a D16A6. Maybe the B-series mounts are the same, but D-series definitely aren't all the same.
Old Oct 10, 2002 | 06:59 AM
Pele's Avatar
Default Re: Mount points for different engines? (rpr)
Basically, I'm looking for a different engine that will bolt onto my existing 4wd tranny. I could fab the mounts if need be, but I'd rather have similar mount points as well.
I have read that using the D16 from a late 80's Integra will mean me loosing my 4wd.
Otherwise, can I use a different head on my existing block?
Old Oct 10, 2002 | 07:28 AM
keithv's Avatar
my friend by a D16Y7 in his mom's 4wd wagon and kept the 4wd. i am pretty sure your tranny will mate to the D16A6 and D16Z6 as well as the D16Y7 long blocks.
Old Oct 10, 2002 | 07:40 AM
xci_ed6's Avatar
Default Re: Mount points for different engines? (breaka_1_9)
I know that the D16A1 does not have the same mounts as any later D-series, but I think they have the same bell-housing bolt pattern. The EW/ZW (which later became D15??) will not bolt to a D16A1 trans, but they have the same mounts. I think you [pele] will need the trans from a 4G AWD wagon (yours is a 3G, right?).
And I think breaka_1_9 was talking about a 4G civic wagon because there are a heckufalotta changes to put a D16Y7 into a 3G chassis (wrong mounts, vac-advance dizzy).
-Dustin
Old Oct 10, 2002 | 08:33 AM
keithv's Avatar
Default Re: Mount points for different engines? (Autocratic_1st_Gen)
yeah i was....whoops! i should have read his signature first.
Sir[Kneighf]
Oct 8, 2011 12:54 PM
phatboycrxhf
10
Aug 21, 2008 12:04 PM
blaak-crx
Apr 23, 2008 09:02 PM
AudioXtremes
Jul 24, 2006 11:02 AM
HamiltonRex
Dec 27, 2004 12:49 PM
