What all should I replace on a clutch change?
Old Jan 27, 2012 | 07:09 PM
mattbatson's Avatar
Default What all should I replace on a clutch change?
I'm doing the clutch/pressure plate on a 200K mile crx, and was wondering about what else I should do...
Throwout bearing, rear engine mount (I think you pull the motor..right), etc...
I thought about pulling the flywheel and doing the main oil seal...but not sure if I should go that deep into it.
any thoughts?
Old Jan 27, 2012 | 07:50 PM
dart8293's Avatar
Default Re: What all should I replace on a clutch change?
i would change the main oil seal i jus did a replacement clutch job on my ef with a zc n i replaced the main oil seal n got a new fly wheel with a six puck clutch n i replaced my hole tranny better to b safe than sorry wen it leaks on the clutch n fly wheel
Old Jan 27, 2012 | 07:56 PM
KINGVEM^^ED6's Avatar
Use honda mtf too
Mine as well get the flywheel resurfaced brah
Old Jan 27, 2012 | 07:57 PM
crvtectim's Avatar
The clutch kit should have a new throwout bearing and pilot bearing included. Also change rear main seal, resurface flywheel, service transmission, replace axle seals if they're leaking, and change any bad mounts. No, you don't have to pull the motor.
Old Jan 27, 2012 | 08:10 PM
mattbatson's Avatar
okay, so it sounds like I should do the rear main seal...and if I have to remove the flywheel, might as well get it resurfaced too...
I googled clutch replacement, and thought what I found was that they pulled the engine...I'll have to go look again and see what I can find...
do you guys just drop the tranny? Cause that is how I would have expected is the best way?
thx
Old Jan 27, 2012 | 08:13 PM
Yep just drop trans
Its better to do the flywheel since its right there
Dont wana have to pull it all again
Old Jan 28, 2012 | 06:16 AM
crvtectim's Avatar
Yea, I've never heard of anybody yanking the motor to do a clutch job. Resurfacing the flywheel is a must, especially after 200K. I'm sure you will find it has hot spots and cracks. The resurface will give the new clutch a fresh, flat area to contact, much like having brake rotors turned when installing new pads. And since your trans is a cable unit, Honda MTF isn't a must. You can use 10W30 motor oil.
Old Jan 28, 2012 | 06:32 AM
91STDFLOW's Avatar
10w30
X2
Old Jan 28, 2012 | 06:39 AM
Dont use motor oil spend a few more bux for mtf
I used motor oil when i went from from four to five speed had thurd gear grind
Switched to mtf grind is gone
Old Jan 28, 2012 | 07:32 AM
91STDFLOW's Avatar
Meh oil is fine for temporary use
Old Jan 28, 2012 | 07:39 AM
Orpheus's Avatar
Use honda mtf...
Old Jan 28, 2012 | 08:56 AM
whited's Avatar
CRX God
It really depends on your budget, and the quality of parts your getting. You do not want to use your old flywheel with a new centerforce clutch. I usually try to replace everything when I am in. But I have replaced as little just the clutch disk itself.
My list is the following:
Centerforce clutch disk and pressure plate
Chromoly flywheel
OEM Throw out barring
OEM Pilot barring
Main seal
New fork, or clean the fork (make sure there isn't any flat spots)
Old Jan 28, 2012 | 02:20 PM
tonylovesjdmEF9's Avatar
well i did this recently and heres what i did
stage one exedy clutch kit
resurfaced oem fly wheel by clutch masters
rear main seal
oil pan gasket
water pump
timing belt
tensioner
cam seal
dizzy seal
valve cover gasket
honda coolant
fully flush the coolant system
MTF honda
thats what i did plus a lil extra more
extra more
clutch cable
battery oem cables
radiator hoses
cleaned and resprayed my bay
great conditon tranny (si)
mounts
cleaned my block and tranny and sprayed them aswell
now i has no problem with my ef no leaks not bs
illl post pics of before and after
Old Jan 28, 2012 | 02:31 PM
acmoc's Avatar
Originally Posted by KINGVEM^^ED6
Use honda mtf too
yep
no need to pull motor though
Old Jan 28, 2012 | 03:09 PM
before and after
Old Jan 28, 2012 | 03:28 PM
Tuck ur bay
Old Jan 28, 2012 | 03:31 PM
.Manny.'s Avatar
Touching My Member
Exedy OEM replacement and flywheel re-surfacing. Exedy is awesome.
Old Jan 28, 2012 | 04:38 PM
Bently_Coop's Avatar
Steve at Heart
Exedy ftw Flywheel suraface a must and rear main seal while your at it always use Honda MTF. If your mounts are busted good time to change them as well.
Old Jan 29, 2012 | 03:58 PM
mattbatson's Avatar
thx a lot for all the advice guys
Looks like I'm doing the flywheel and main seal, along with pilot and throwout...will also do the rear engine mount.
I think I may pull the mount, fill it with windo-weld, and re install....had good luck with that in the past
lots of good info here, really appreciate it
Old Mar 25, 2012 | 05:04 PM
mattbatson's Avatar
so it has been a while, but i got busy with other stuff and it isnt my dd...
so got the tranny back on.
I was pretty damn careful to make sure the throwout bearing was installed and worked correctly and greased...that the clutch plate was installed facing in the correct direction (the exedy has a stamp on it saying which side faces the tranny)...torqueing the pressure plate on correctly in criss cross pattern, etc, etc, etc....
anyways, I hooked up the engine/tranny mounts and then the clutch cable and got into the car to check the clutch feel
it doesnt feel right
normal clutch feel is kind of an increase in pressure in the pedal, smooth, but with some resistance.
this feels smooth, but no increase in pressure like you would expect from a throwout bearing hitting a pressure plate....just feels kinda dead?
So I checked the clutch cable and noticed it had kinda pulled out a little from the spot where you turn the adjustment ****, so i fiddled with the adjustment a little, but it still didnt feel right
god I hope I dont have to pull the tranny back out, crap....
I'll keep messing with the cable and keep asking questions on here
thx
Old Mar 25, 2012 | 05:09 PM
EFnCRX's Avatar
well said. Temporary use! Buy 2qrts of honda mtf about $15.
mysicivic1991
Apr 10, 2007 08:56 AM
k_lude
Oct 31, 2006 11:27 AM
TnLude2000
Feb 23, 2005 06:16 PM
94gsr_vtc
Aug 26, 2004 04:57 PM
IntEGNYC
Oct 31, 2003 06:58 PM
