400whp with 650cc injectors is it possible?
Hello fellow honda-tech and all tuners,
Is it still possible for me to make 400whp with precision 650cc injectors (new penstyle)..?
Here's my set up:
Head
Stock B16 with gsr cams
victor x manifold
omni 70mm throttle body
Block
Gsr block
Cp pistons
K1 rods
Acl bearings
Turbo set up
RLD-Fab ramhorm manifold
PTE 5857 turbine Scover anti surge
3 inch dp, 44mm wastegate
Fuel set up
255 walboro intake pump
Aeromotive fpr
steel braided lines
Here's my set up:
Head
victor x manifold
Block
Gsr block
Cp pistons
K1 rods
Acl bearings
Turbo set up
Fuel set up
Aeromotive fpr
steel braided lines
well if you have 50 psi fuel pressure and your running 100% duty cycle i believe the math says 450 hp is achievable, so imo i would say yes 400 is definately possible and it think that would be a great number for your setup, im currently working on making the jump from 3 to 400 hp, i chose to go with 750s though.
once u get it to the tuner everything will be there right up on the screen, i wouldnt recommened pushing the injectors past 85% duty cycle. but i really dont think you will have to get 400, pay the money for a good tuner and u should be fine. ive seen guys make 350 whp with 450cc injectors on 90% duty cycle, so lots is possible it all comes down to reliability really and what risks you are willing to take.
I want the car to be reliable as possible, I'm goin to turn the car as my daily.. so worst comes to worst if i dont make 400 by 85% duty cycle, then i'll just stick to whatever power it will give me. As long as it last me for good amount of years. I'll be fine.
HOM DON
10
Apr 26, 2011 03:49 AM
