injectors
Old Aug 27, 2005 | 12:43 AM
civic_driver's Avatar
Default injectors
So the d15b7 injectors (235cc) are good for 180hp right? So I can round 5-7psi with a 14b turbo on stock injectors, correct?
Old Aug 27, 2005 | 12:53 AM
SFWD 1934's Avatar
Default Re: injectors (civic_driver)
180 whp
BSFC:0.60
Duty cycle: 0.90
Rail PSI: 50
294 cc/min
That is the "minimum standard" that I would go with. So round that to 310 cc/min. Leave yourself some headroom for more boost down the road.
Jason
Old Aug 27, 2005 | 01:43 AM
I think stock psi on the fuel pump is around 43-47psi (and that's with a new pump). It's probably about 35-40psi at the moment.
I'm planning to get 450cc injectors since they are cheap but if it weren't for the price I'd try to get away with smallest possible and for the hp I wanted, 235cc would've done it. But even new 235cc are more expensive than the 450's so I'll just use those instead :-)
btw, where can I read more on fuel/liquid dynamics? I'd like to better understand the relationships between volume, psi, duty cycle, etc.
Thanks!
Old Aug 27, 2005 | 03:03 AM
quick question:
On a 14b turbo with internal wastegate (say it's set at 10psi). Can I lengthen the flapper rod in order to get to 0psi on the wastegate, and then attach an MBC to increase boost pressure? Is that possible?
Thanks!
Old Aug 27, 2005 | 06:51 PM
Anyone?
Mephistopheles
Feb 15, 2021 05:17 PM
mattyv
Aug 11, 2009 04:41 PM
adhana2
May 22, 2003 05:26 PM
jamal-188
Oct 10, 2001 12:03 PM
DIRep972
Jul 14, 2001 02:56 PM
