Timing gear stuck on crank
Old Jan 27, 2012 | 01:35 PM
preludeNApower's Avatar
Icon2 Timing gear stuck on crank
Any tips/tricks on getting the timing gear off the crank. Mine seems to be stuck on there. I have fought with it for over 2 hours now. Soaked it with penetrating oil, tapped it with a chisel, loosened the oil pump cover and tried to pop it off that way... I cant F***ing get it! What next?
Old Jan 27, 2012 | 01:52 PM
element600rr's Avatar
Default Re: Timing gear stuck on crank
sometimes on h motors the woodruff key gets wedged in the back of the gear .. take a small pry bar place it behind the gear apply light pressure and tap the gear with a hammer ( lightly as not to damage the gear ) you can also tap the end of the crank while applying pressure .. ive had to do this in the past .. just be gentle and dont beat the **** out of it .. let us know how it works out ..
Old Jan 27, 2012 | 03:54 PM
minilogoguy18's Avatar
Yeah 2 short pry bars behind it and just wiggle it off.
Old Jan 29, 2012 | 04:41 PM
finally got it off... distorted the washer behind the gear but I got spares.
Old Jan 31, 2012 | 09:19 AM
JDM-h22a's Avatar
^^^ how did you manage to get it off cuz I'm in the middle of doing this today lol
Old Jan 31, 2012 | 01:50 PM
pentaq's Avatar
bearing puller will do the job
Old Jan 31, 2012 | 07:25 PM
i had a small pry bar/nail/tack puller that i wedged behind the washer and was able to pop it loose.
GL
Old Feb 1, 2012 | 02:15 AM
JDM-h22a's Avatar
I got it all off got the tensioner off but is there something specific i should be using to get the tensioner compressed to go back on the motor I looked in my chiltons doesn't say anything really about how to keep it compressed sorry for thread jack
Old Apr 22, 2012 | 01:24 PM
SonicRacing1's Avatar
where do i get the bearing puller can i rent it or does harbor frieght sell it if yes to any any pics on how it looks any help appreciated
Old Apr 22, 2012 | 02:01 PM
Learned a neat trick recently, if you have a large socket like one you'd use for axle nuts (32/36mm) just place it on the sprocket, it needs to be deep enough so the crank wont touch it, tap the end of the socket a couple of times with a hammer and it'll free the sprocket.
Old Apr 23, 2012 | 04:29 PM
Gamble_wrx's Avatar
this. works like a charm.
Old Apr 23, 2012 | 04:51 PM
3DOTProductions's Avatar
thanks for the tip
Old Dec 4, 2012 | 05:52 PM
Raven McCoy's Avatar
i think my crank is swedged or ballooned out and i think that is why i cant get my gear off my jdm single cam it is loosely fitting but still tight cuz it can only wiggle just very slightly. I can get it to move about 1/4" with pry bars but stops in the same spot everytime. I've been messing with it for hours and thats my only conclusion......any suggestions??
JayDaTroll1
Aug 3, 2018 12:11 AM
B_Swapped93
K Series
Jul 18, 2017 08:39 AM
Svery
Feb 8, 2010 01:21 AM
SIXTY-1HATCH
Sep 13, 2006 08:43 AM
tek_civic
Jun 1, 2004 01:43 PM
